WTF did I break now?
Doppleganger
OH-MI: Just like it sounds
Did the rear leaf springs. Used 2 floor jacks so everything was lifted even and orderly. Got everything in and found this this AM. Front small spot is the rear main is leaking (motor is coming out this Fall for a refresh and will fix that then)....but this pond looks to be from the output shaft seal? Wasn't there a day ago.
Everything on the truck is original 1985 so not surprised.
Is this a PITA to fix?
TIA
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
Easy fix. Pop the driveshaft out. Knock the seal out. Drive the new one in. Make sure you have a way of driving the new seal in squarely before removing the old one.
Joe
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
If it is in fact leaking from the rear tail housing it is an easy fix. Pull driveshaft, pop out seal with bass screwdiver, clean, tap new one in. Return driveshaft and ...:burnout:
The88
Mhmm
South Louisiana
ThatGuy
Hell if You wanted to do a reseal. By the looks of the case it probably wouldn't hurt to drop it, clean it up and do an overhaul.
Doppleganger
Thanks fellas! I'll put the gun down and throw out my note now. Is there one brand of seal thats superior over another? I know the Euro shtuff.....these, not so much.
I'll have to look into whats involved in that lil venture. That case is really clean underneath the spuge....was wanting to clean it up anyways. :)
Thanks!
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
check for play in the bushing. if it is excessive you will need to replace it to . or the new seal will leak.
jlyon1006
