Would 12 volts on a 6 volt system kill your ignition system if its not converted?
Also, would a generator putting 6 volts to a 12 volt battery lend to it, if in bad shape, exploding?
Asking for a friend
Jethro224
Illinois
Need a lot more info.
I wouldn't just hook up a 12 volt battery. Minimum you'd need a 12 volt coil and alternater. Also plenty of the old 6 volt stuff was positive ground. Any 6 volt bulbs need replaced. Sketchy wiring??? Lots of questions to answer.
Doo a search on the intergoogle for how to convert.
Auburn, Washington
First question. Yes.
Second question. A 6V charger will not charge a 12V battery.
As to exploding? Never tried it because it’s a dumb idea and won’t work anyway.
Based on your pointed, yet vague questions, I’m guessing your “friend” is trying to start an old 6V vehicle sitting in a pasture in WI with an old 12V battery that has been laying in the corner of the barn. Am I close?
If you ( I mean your friend) want to get it running, either buy a 6v batt or convert the vehicle to 12V or just go tip a couple cows in that pasture for entertainment instead. 12V will fry a 6V system.
jjester6000
Illinois
Jack
C1500
Asking for a friend
The starter would probably be fine, but you'll need a 12v coil to get it to run though.
Also, the generator would not make enough voltage to charge the battery, but you could modify it adding a step-up transformer before the A/C rectifier in the generator.
(I've been trying to get my 1951 Studebaker running for the past few days)
I did have the system hot-wired for 12v, but I did eventually break down and buy a proper 6v battery.
Thats what I feared, gentlemen.
Fried my-er,, my friends 1951 massey harris tractor with 12 volt. Explains why it blew up(battery)
legopnuematic
Licensed Junk Dealer
MO
Spencer
Starters and generators are 6v are fine on 12, just the voltage regulator would need to be changed. can jump a 6v system on 12 no problem, just don't try to use the lights or anything. if the charging system works then it'll run without a battery at all. Lots of people used to run 8 volt battery's in a 6v system to get a little extra punch in the winter. The coil likely won't care if its only for a short while, otherwise put a ballast resistor in line with it or use a 12v internal resistor coil.
Positive vs negative ground doesn't make any difference 6v to 12v
Jumped a few trucks and tractors with 12 and never had any issues. If it charge then don't leave the 12v batt hooked up, but if it has no generator/not outputting itll run.
Nah it totally ran a 12 volt battery far too long, depleted 2 charges(albeit a weak battery) and jumped a few times probably goiing well over 12, all with a bad GROUND strap(got red) and eventually blowing up the battery. That was when I attempted to start it. Good thing i was behind the fender
rt66paul
California
paul
1991 suburban
You can fry the points and condenser sending 12v to them. As I recall, even late 60s vehicles used a resistance wire before the power to the points and condenser. The HEI units need 12v, but the stock units should not.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Ran a twelve volt battery with a six volt starter for years on my 53 chevy, replaced the gen with a 12v alternator, and all the light bulbs. Use a ceramic resister for the points.
SquareRoot
There's no wrong answer and the points don't matter.
legopnuematic
MO
Spencer
Points and most condensers are not voltage sensitive, as long as the condenser is the correct microfarad rating for the application it should be fine
Sent from my Moto Z (2) using Tapatalk
Well I feel the battery exploding likely caused the no-spark, and everything rusty and old probably could use a once-over
Auburn, Washington
^ Im confused... but the battery exploding in the tractor was not due to it being 12V but rather a live short possibly, Bad ground, warped battery plates low on water, causing a spark , or over charging.
However not knowing what happened and not knowing the whole story, makes it tough to say.
It was a short circuit because the lead plates touched.
Auburn, Washington
Then why did you ask if it was from charging with 6 volts if you knew that. Also curious how you know that (albeit a viable cause of explosion)?
atup1996
