Won,t start
david468
Florida
Ok I have one i have a 1987 chevy c10 s/b pick up 350 /700r4 race trans my problem is that i can start truck go to 2 or 3 places starting and stoping no problem but then turn the key fuel pump starts truck wont after i wait about hour or less she starts drives fine history thought it was battery changed it 2 x in frunt of napa still wont start i got wire ran it from positive from battery to positive of solonoid starter engages engine roles still wont start 30 min goes by she starts ok im open for help. David
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Ok, I have a 1987 chevy c10 s/b pick up, 350 /700r4 race trans.
My problem is that i can start truck, go to 2 or 3 places, starting and shutting off no problem.
Go to start it again, and the fuel pump primes, but the engine wont turn over.
If I wait about hour or so, it will start.
She has started, and driven fine in the past.
I thought it was battery, changed it 2 times in front of napa, and it still wont start.
I have a wire and ran it from positive battery terminal, to positive of solonoid, the starter engages, and the engine turns over, but it still wont start.
30 minutes go by, and she she starts.
Any ideas?
I had to fix that^^^^^
First of all, welcome to GMSB!
Has your truck been modified at all, or is it stock?
Old battery cables, and dirty terminals, both on the battery and starter, will cause heat related starting issues.
If you have the funds to do so, I would go ahead and buy a new positive, and negative cable, and see if that cures the problem. There is a bolt hole on the front of the passenger side head that would be a perfect place to relocate the ground cable to.
A ground cable with a few brocken strands, and corrosion, is like a kinkedngarden hose.
It wouldn't hurt to see if you can re-torque your starter bolts as well.
Vapor lock !!!
Retard the timing a bit helps.
Also if running a Qjet, probably have leaking well plugs.
Welcome aboard.
Cranks, but won't start? Ignition module usually. You will want to check for spark the next time it acts up.
I read that is fuel pump primes but won't turn over. :shrug: Which leads me to believe it doesn't turn over.
Jims86
Patterson,Ca
5.7 TBI
the fuel pump prime shot clears any possibility of vapor lock.
x2 on the ignition module....or even the coil.
yeah, scratch that I wasn't thinking TBI. But still, if he says not turning over, that means it's not cranking huh? Not sure how that would have to do with IM or Coil. If it was a crank but no start then I'd think so.
Oh I see, I read the part about it turning over but not starting... when a wire is run from the battery to the starter solenoid.
Is the ignition turned on when you jump the stater solenoid?
Jims86
Patterson,Ca
5.7 TBI
Damn Andy, good catch....I didnt even think of that. And I use a remote starter switch all the time.
david468
Florida
Thank you for the welcome,trans got good deal on so thats the race thing battery cables 2.0 welding cable new ends they dont sell these i made them really heavy duty i will check body ground to eng and retorque bolts but never seen this problem before .David
david468
Florida
Vapor lock !!!
Not timing just wont even roll wait 30 min she starts David
david468
Florida
Hi key switch on when jumping starter solonoid still wont run that taks starter out of lop it seams like hot wire from key switch not energised David
david468
Florida
Hi turn key fuel pump primes but wont start wait 30 min to 1 hr starts like nothing wrong ? David
bryanedge117
