Wide rear wheels.
Some tire shops will let you rent/ borrow a wheel right tool from them to measure. You can also make a tool in a few minutes with a couple pieces of scrap wood. One piece bolts to face of drum and the other piece on top like a T. You just keep trimming until you have the height, width, backspacing figured out.
I recently made a fitment gauge out of some scrap steel, a paint stick and a coat hanger. It made it real easy to visualize how the rim and tire would fit in the wheel well. I bent the coat hanger roughly to size, according to the specs of the tire I wanted to run.
OEMBent
Indiana
Greg
N/A
N/A
N/A
This truck has 15×8″ in the front with a 4″ backspace, 245/60/15 tires. The rears are 15×10″ with a 5″ backspace, 295/50/15's.
That is one nice truck! I really like the tire/wheel combination.
Raider L
Shreveport, LA
William
@82sbshortbed,
OH MAN!! You gotta' be kiddin'. What tread is that? It looks like rock crawling tread but with a width used to trek across the Artic!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
3:42 gear and 4L80E transmission ;)
Well ****.. that was almost exactly the gear ratio i wanted to run, 3.42 on around that tire size
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
running good here so far! ;)
