Which shocks do I need?
D-Short
Tx
D
Hello everybody, started the 4/6 drop today on the 84 C10
2" drop spindles with 2" lowering springs with flip kit in the rear.
Which shocks set-up do I need?
Brett77
Glendale AZ
Brett
502 stroker
Measure distance to after lowered and get a good quality shock.
D-Short
Tx
D
Brett77
Glendale AZ
Brett
502 stroker
From shock mount to shock mount!
WesN
Edmonton Alberta Canada
Wes
C1500
With spindles the shock height or length remains the same it is shorter springs that shorten the required shock length. I run 2” spindles and 2” Bell tech springs and after checking mount distance ended up using the stock shocks and it works fine. With a 3” spring you might need shorter shocks but “measure twice buy once”.
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
Belltech Nitro Drop 2 The part numbers are 8511 and 8527 is what I used on mine, got them from Summit work fine
Raider L
Shreveport, LA
William
Yeah man, Belltech is some good stuff. They've got every length, and excellent quality.
I put them right up there with QA1 stuff. I wish I could afford it, but there's plenty of good stuff out there.
zapattack
