Kilian
- Mar 25, 2018
- Wisconsin
- K
- C2500 on its way to a K2500
Hello all, I posted this over on Cliff Ruggles' Quadrajet site but will put the question here as well. I'm trying to figure out the best Quadrajet to use on the engine in my 83 GMC C2500 (3/4 ton).
Here are the specifics:
350 engine (not original, CMJ suffix and engine VIN denote possible 1975 vintage)
Edelbrock intake
Moving to stock exhaust manifolds with dual exhaust
TH400 transmission
3.73 Rear Differential
Currently there is a 17085213 0576 HPB Q-Jet on the truck.
I also have three other Q-Jets I could use, 17082226 1482 DUU, 17081226 0231 DDS, 17080244 1640 CJL.
The current Q-Jet doesn't appear to match up with the Edelbrock intake directly (hopefully the picture posts correctly) but the carb sits inside of the round bosses on the manifold, if that makes sense. Maybe that's normal for an aftermarket intake.
Assuming that all four Q-Jets are stock and haven't been messed with internally, which is the best for this application?
The GMC is my farm truck that does some trailer pulling but doesn't see a lot of miles each year. Right now it burns very rich at idle, won't hold idle very well when hot, and I'm getting less than 5 mpg. I plan on doing the exhaust change this winter and thought I'd improve the carb performance at the same time if possible. Thanks for any help.
Edelbrock intake
TH400 transmission
