- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
So the AVS2 or 9895 would be a direct swap onto both the alloy oem spreadbore intake on my 70s 350 -AND- the high rise oem iron intake for my 85’s 4.3L V6? Asking because the Qjet I have needs to be rebuild and will not come apart. Could only get the lower plate off for a gasket replacement. Top 2/3 are stuck solid.
No, just an aftermarket intake with an open or split/open plenum design that is meant for use with a spread bore and square bore carburetor. Otherwise an adapter would be needed.
While that AVS2 has different sized bores, it essentially is still a square bore carburetor.
