Where does this wire go?
Turnbull_Austin
Gulf Breeze
Austin
G30 K-Van Pathfinder
5.7 v8
Good afternoon,
1982 Chevy G30 4x4 pathfinder van
Power the Headlight switch:
Power to the head light switch was spliced in when I bought the van. Can’t find where the power is supposed to be ran from?
I have read the electrical semantics but can’t find answer or able to look at a local example.
Where does the power to the light switch originate from?
I can't say where it originally sourced power, but it was a constant fused 12v. So as long as the current power source is also fused and constant, that's really all that matters.
Turnbull_Austin
Gulf Breeze
Austin
5.7 v8
It it not fused. It was spliced directly from the red wire going to the fuse block.
Dave M
Banned
Australia
Dave
That's correct, the main wire splices off to the ign switch/light switch. It is unfused through the firewall/fuse block. The power TO the block is from the starter motor cable, via a fusible link. Also don't like the way that spade terminal is hanging out of the plug.
SquareRoot
I thought headlights used circuit breakers for safety?
BMac Attack
Salt Lake City
Barry
Does anyone recognize this plug? Seems to tee into the wire powering the cigarette lighter. I’m not sure what it goes to. If anyone recognizes it, let me know. Everything seems to work fine.
WFO
Texas Panhandle
Maybe for a constant hot wire for an aftermarket radio.
thatgermanguy
