Wheel paint
78C10BigTen
pennsylvannia
C10 BIG TEN
So im doin some sandblasting and repainting of my factory ralleys and i know its argent silver but my question is where is the cheapest place to buy it in spray cans? And also should i prime them before the argent?
Not sure about the Argent Silver, but I would certainly prime them first.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Definitely prime. The rustoleum professional high performance spray paint is pretty good stuff. The ‘aluminum’ color is the closest to argent silver. They also have ‘light machine gray’, ‘dark machine gray’, and ‘smoke gray’ all in professional high performance line of spray paint. Krylon also makes a wheel specific silver that I haven’t tried. Don’t get lesser spray paints. From what a paint professional has told me, the highest end rattle can paints are already borderline on durability for wheels and expect to touch up where weights are removed when rebalancing.
Getting any of the colors I’ve mentioned in a high solids base and shooting through an hvlp is preferable for durability.
I went with dark machine gray
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Soapy dawn water and a scotch brite pad before you paint. Mineral spirit wipe down is a good idea too.
78C10BigTen
pennsylvannia
C10 BIG TEN
Tried this one as a test subject. Bead blasted, wiped with an automotive surface cleaner then painted with rustoleum 2 in 1 gloss black. Theres some heavy pitting on the bead area, anybody think that will be a problem sealing a tire?
jetmech
Tx
Robert
This is what I use for ralley wheels: Clean/sandblast then prime with Rustoleum red primer, dry overnight, then the back with semi-gloss black and let that dry. The front gets a covering coat of Rustoleum aluminum and at that point you think you really screwed up but before it completely dries, I usually can't wait but a couple of minutes, spray it with a Rustoleum gloss clear. The clear transforms the awful aluminum into a beautiful factory argent color. I know it sounds crazy but it is the best spray can method I have found. I have used automotive mixed paint for GM ralley wheels but not anymore. This is too easy and no spray gun cleaning.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Going to wet sand these and get my tires mounted...finally
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The rustoleum red oil base in a bucket takes forever to dry, but it’s awesome primer for the money
78C10BigTen
pennsylvannia
C10 BIG TEN
Well ive done 3 plain steels so far just for ***** n giggles before i play with my factory ralleys, coming out good i think. Not all 3 are pictured.
4WDKC
Southern Florida
Kacy
before you get to carried away, test one of them with brake cleaner, it removes rattle can paint.
78C10BigTen
pennsylvannia
C10 BIG TEN
Theyre gunna be my winter rims im not too worried. They have 3 coats of clear
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
This is what I used on my grill last year and came out nice. If I was going to paint rally wheels or any others, I would definitely use this. Easy to get local at AZ.
78C10BigTen
pennsylvannia
C10 BIG TEN
How close is ford argent to chevy argent?
78silverado
