hirschdalechevy
- Mar 8, 2011
- norcal
- rich
- k-30
you blazed the ties off 3 times with no issues the 4th time it hopped, does the engine still feel as strong as it did? Have you checked for broken springs, loose ubolts, missing shims etc?
For sure check everything like kacy said , but if you are hooking up better you are wrapping your springs up and your pinion is trying to come up to far if nothing is messed up just get some shims to put your pinion angle down a bit and you should be all good. I have played with pinion angle's a lot on my drag car and 4x4's and have been able to stop wheel hop by doing that if nothing is broken.
