Wheel choices for 4x4
scenic760
SoCal
Suburban K10
Wheel choices seems to be all over the board with Squares but the 4x4 hubs in particular pose a problem for a lot of wheels it seems?
It also seems the spec'd centerbore is way larger than he actual hub?
My thought was a late model take off wheel from an HD truck to clear the hubs and use wheel adapters to fit? Has anyone tried this? I have two OEM wheels I'm looking at and I prefer the oval mags vs the spokes but the price is right on the spokes if the adapters will work?
I have read that the 8 lug wheels from a full sized Hummer (the one on a Suburban chassis?) will fit on a squarebody, but have never seen it done.
Craig 85
Nashville, TN
454/TH-400/NP205
I've owned 8 Square bodies (20 & 30 series) and put aftermarket wheels on them all. You're correct, most aftermarket wheels have a larger center bore them OEM. I've never had an issue with breaking studs. The wheels will center on the tapered lugs.
The PY0 wheels fit on 8 lug Squares with no issues, mine came with them. You would need to check the hub diameter on the second set you pictured. They still my be too small.
@75gmck25 yes H2 wheels fit on Squares.
rpcraft
Robert
LS 6.0 364 CID
I'm a 4x4 owner so I am a big fan of OEM rally wheels if you are sticking with a 31 or 33. Now days bigger wheels are the rage but those clown college looking things that brodozers use have no place on a square. Alternatives to stock for me are American Racing AR 62 in brushed finish, AR 172 in Polish or Black, and then the classic chrome or white Spoke/Wagon steel wheels, and then there is also the beloved and classic 5 slot aluminum "Mag" from Mickey Thompson fame.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I am a fan of tall skinny tires as most of my 4WD stuff is in snow.
Running the Pro Comps til I get my steel wheels readied for the Dog Dishes.
Auburn, Washington
Wait a minute. You have a half ton, no?
The wheels you showed are 2 different lug patterns also, btw.
Don’t do what you’re thinking. 6 to 8 lug adapter.
scenic760
SoCal
Suburban K10
You are correct, mine is a 1/2 ton and I was going to either use adapters or have them drilled and filled...you say no on the adapters eh? I was thinking that might be asking for it, I haven't had any experience with them.
Those polished mags are pretty cool 45tt!!
The problem I'm seeing is that the center bore on most of the 6 lug wheels aren't big enough for the front hubs? I have seen a couple forums where guys have taken a router to the center bore but that seems sketchier than an adapter?
It looks like, of all things, a Toyota spec wheel would fit as it has the same bolt pattern with a large enough center bore?!
Joshua Keith
Memphis
Joshua
These are my 2 personal favorites. I believe the top is something similar to Pacer 320C. I believe the bottoms are AR62’s. I haven’t decided on which ones I’ll be getting yet.
78C10BigTen
pennsylvannia
C10 BIG TEN
Always aluminum slots!!!
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
I second these rims. Old school look. I got mine in 17x9 flavor. Went with 17's for future tire options and possible brake upgrade in the 2nd pic. Or in the 1st pic
you could look for those like someone else mentioned.
78C10BigTen
pennsylvannia
C10 BIG TEN
I LOVE those slot wheels but F'N HATE those bfg AT tires!!! Kinda sad that everybody uses them when they suck so bad.
rodfarm
