Wheel bearing exploded!
Boonie
El Dorado, KS
Brent
found this on binder planet, think its what youre looking for.
* Rear axle shaft bearing retainer nuts (semi-float).….25-35 lb/ft
88SUB
San Diego
Sean
V1500
5L NA V8 overhead valves (OHV) 16V
I thought the same and currently have it at 35lb/ft but the place I bought the bearings from gave me a number of 75-85lb/ft
I should mention that my axle shaft is 35 spline and 6 lug
88SUB
San Diego
Sean
V1500
Anybody else? Want to try and take her for a spin this weekend and not burn up my bearings again
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If you know the thread size there are standard tables for torque. You're not trying to hold the Titanic together, so 35 lb/ft sounds fine.
CSFJ
Yeah, the 35 lb/ft sounds about right. If your still a little concerned, maybe some blue thread lock too.
88SUB
San Diego
Sean
V1500
Thanks guys.
My concern was not tight enough or too tight and smash my seal and add unwanted pressure to the bearings, causing them to lock up and explode again.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Just had the right front bearing explode on my 77 K20
Not pretty , but limped it home
$375 for new spindle, bearings ,hub rotor, and locking rings
Fun swapping it in the driveway in 37 degree weather
Least it stopped raining ....
And the local 4 wheel parts store was able to get everything overnight delivery
88SUB
San Diego
Sean
V1500
So now my other side, which never had issue (Rear pass) is now leaking.
I'm wondering if I did not press bearing on enough? What is this I see in some videos that people use Permatex near seal to prevent leaks?
bglendon
