What should I go with on exhaust manifolds?
Stock Manifolds or Headers?
  • Stock Manifolds
    Votes: 3 25.0%
  • Headers
    Votes: 8 66.7%
  • Other
    Votes: 1 8.3%
  • Total voters
    12
Yeah...those are really nice. Those ceramic headers will always be higher but will dress up the engine bay considerably. I wished I'd gone with them on the '77 but I went with the black and in short order the black burned off and they're more of a grey now :)
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
If you buy painted (black) headers, look in your engine bay and imagine them in 2 or 3 years rust colored instead of black. If I had it to do over I would have went with ceramic coated, chromed, stainless, anything but regular old painted steel.
:word: The painted ones are much cheaper but definitely don't look nearly as good long term. When I get to the point of doing it over again I'll spend more money in this area for sure :High 5:
davbell22602
Bunker Hill, WV
I Dont
Have
One
Thanks C4. Thats what I dont want to happen in 2-3 years is rusty/paint peeling headers.
Then you'll probably need to fork out $400+.... then get the rest of the exhaust ran after that.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Not problem. Probably replace the mufflers and cats too. But going with hi flow cats. Undecided on mufflers yet but leaning towards dynomax.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
are you planning on going with or without cats?
for '90 I believe he has to have cats unless he knows someone.
Those things are bad ass.
...on the driver side header you can see a place where the 02 sensor will go right before the 4 pipes come together (it's threaded in there). You'll need that on any set of headers you get in order to pass inspection.
It may not be an issue, but I would figure you'd want the oxygen sensor to be reading all four cylinders instead of just one. Like on the headers that C4 posted, the fitting is on the collector instead of the tube.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
How far back does your state require testing? I'm riding out stock from the cat forward for at least 2 more years. After that, this emission rip-off will be history, and I'll be looking to go long tube with pipes & mufflers only. Hopefully that won't screw with the TBI???
Missouri's is based on year of vehicle and not age. I believe for our squares the cut off is 82 and newer have to have cats but before then they don't care about emissions so mine is just headers into dual flowmaster 40 series and straight out the back.
crazy4offroad
K-10
350/SM465/NP205
77 and newer require cats here. Unless you're on antique tags.
tinbox
