What non 73/87 parts have you swapped into your squarebody?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
The ones I know of in my well used and slightly abused ‘79...
85 C30 454
03 E350 trans cooler
98 Windstar electric fans
99-07 Chevy tailgate hinges
?? square body bench seat, power window door panels (and manual regulators lol)
?? 168t used chev dual pattern flex plate from local trans shop
?? newer high torque starter from an sbc
Lots of new parts too but they aren’t as interesting.
Here’s the old girl hauling home the next project.
Dont forget those hot f150 sideview mirrors...
Camar068
Kentucky
10 yrs Air Force
autodim/temp/compass rear view mirror. I forget which one I got, just pick one you like that will fit between the sun visors to your liking.
RoryH19
Rory
R10 Silverado SWB
My k5 is a list of what GM parts I can use.
04 Escalade:
6.0
4L65e
radiator with built in trans cooler and overflow tank
Engine oil cooler
power steering pump cooler
07+ Escalade
Dual electric fans
91 Suburban/Blazer
NP241c with electric speedo
transfer case cross member
gauge cluster
Soon to be added:
14bolt semi float rear from a 88 - 98 Chevy pickup
For my R10
I used the serpentine setup from a 90 - 91 suburban
Also replaced the factory under bed tire carrier with a winch style from a 88 - 98 Chevy pickup.
I'm there are other parts I've used.
MikeB
Seen but couldn't find information about it
*Silverado Brake Booster
*Master Cylinder
I'd like to know how these parts will work on a manual brake truck. Specifically, will I need a different pedal pushrod, and is the pedal ratio different? I realize I will have to re-route the brake lines. In fact, I would probably go with a new proportioning valve mounted to the M/C to replace the 37-year-old one on the frame.
MikeB
My 82 C10's non-73-87 parts:
  • 1997 C1500 roller cam 350 block and new Vortec heads
  • TH350 trans with CBOP bolt pattern -- kind of an odd-duck
  • American Autowire wiring harness and fuse panel (not the $700 model, but a $280 universal kit)
Donald
Loris SC.
Don
GMC 1500
Seat out of 88 c10 with some reworking of seat mounting .
gmachinz
Harnessworx Inc
Iowa
Jabin
Well my 86 K10 shortbox has:
1979/80 C10 door speaker pods
1990 Suburban seats, power mirrors
1992 S-10 Blazer leather steering wheel
1993-97 T-Bird 2-speed electric fan
1995-ish GMT400 serpentine kit
2005 Denali Yukon disc brake rearend
GMT400 underhood retractable light
1994-97 Impala SS 140A alternator
GMT aluminum master cylinder
1999 S-10 Blazer factory CD player
BMW dual temp switch kit for electric fan
Lots more little stuff....mostly various year squarebody adds.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I guess the truck I’m building could be called Frankenstein, it’s got parts from countless other trucks. Things I have upgraded include:
Tilt column built from a pile of theft recover columns. The column includes delay wipers, flash-to-pass, and the headlight dimmer on the turn signal lever
Power locks, and power windows with the express one touch auto down.
Auto dimming rearview mirror with compass and outside temperature
Chime warning option, sliding rear window, the 4x10 speakers behind the seat, all from a donor truck.
Since my truck was originally 350 Olds diesel powered, when the factory engine died a 455 Olds was installed. I ditched the leaky Hydraboost system and installed a factory brake booster, and big radiator from a wrecked big block truck.
I’m sure I have forgotten a few things, but those are the major changes. This was my grandfathers truck, it’s worth exactly it’s widget in scrap to most people. But it’s considered family now.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
99 C3500 master cylinder
05 Silverado front seats
00-07 Tahoe 3rd row seat
I thought there’d be more but I think that’s it.
Do you have any pics of the silverado front seats???
I'm getting tired of my '85's tired old bench seat and was thinking of trying to fit in a late model Silverado seat with the buckets and console combo.
Battlac40
New Mexico
James
K1500 Sierra Classic
Jeep steering shaft
GMT400 Power distribution block
Vortec heads
95 Ford Camper shell (only issue it hit the cargo light)
Electric fan
Short box or long box?
Battlac40
New Mexico
James
What a loaded question!
I think mah C20 squah roundeyez has parts of...11 different vehicles in it? Nine? Eleven I think. Even boat parts!! ...**** man, the sky is the limit!
92 Astro Van
94 C1500
82 Camaro
85 Corvette
79 Impala
80 Camaro
82 Thomas schoolbus
77 K20
77 C20
69 Corvette
84 Glasstron
75 Blazer
I just realized that I really should work in some airplane parts! :D
Good luck with your thread.
Here's mine...
https://www.gmsquarebody.com/threads/1977-c20-babe-the-blue-ox.12097/
What came off the astro van?
DBarre
Rockport, Texas
Dustin
250c.i./4.1L
I have an AX-15 5 speed manual out of a 1995 2wd Dodge Dakota. It was a big upgrade from the 3 speed!
ALL-OF-IT
Nebraska
Adam
323.425844 cubic inches
So you're wanting to convert from manual brakes to vacuum assisted brakes with the 99-up GM truck brake booster and brake master cylinder. (If I understood correctly, below is my best guess)
I think the pedal pushrod will be appropriate with the booster/mc it is fitted for. The pedal throw in most vehicles are fairly similar, so I would guess using all the newer parts would be best. And modify brake pedal lever to what you think is going to work best/pedal placement
For brake proportion I would suggest a adjustable brake proportioning valve. Usually in the $40-$100 range
Sent from my SM-G950U using Tapatalk
kobedemello
