Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
Not square body but close, GMT400. My nephew's truck has been sitting a few years and me and my brother decided to get it tuned up for him. We got the 350 in it back running and discovered milkshake oil. I called head gasket then from some other clues but my brother wanted to be optimistic. Changed oil and after several run cycles over the next few weeks it looked like everything sealed up. I'm on the road Saturday and got the message that we had milkshake again. I go out Sunday and we do compression check and #3 and 5 are completely dead. All the rest all read strong. We start pulling everything off to pull the drivers side head. First surprise, the bottom of the intake is cracked, directly below the TBI had a crack a good 4" long diagonally, no wonder we kept having gassy smelling oil. We hit a stall at that point, waiting on a puller for the power steering pump. Sitting around resting for when that shows up I kept seeing a very slow drip of water down the valley, thinking its from one of the water jackets I ignore it for a bit, then shine some light on it, there's a 3" long hairline crack in the block along the valley that's weeping water from the water jacket. We called 350 time of death at 12:30pm 4/6/2-25. Luckily we have another clunker truck the nephew can have.
hoagster
California
K10, 1500
5.3l
I still have need to paint the bed, front fenders and the top of the hood. Life got in the way, and I sheltered a few horses last year because of the Park Fire which killed painting. Hard to paint when the horses think your going to feed them every time you go out to the barn.
Strick
Dunn, NC
Harold
C20 Crew
Do I see a '63 Galaxy behind that lifted 4x4?
Yes sir, that's "Big Girl", the black eye of the plantation! No, it's the only Ford in a yard full of GM vehicles though. It's a 63 1/2 Fastback 500 with a 390. It is my favorite of the Galaxie flavor and I had ties to the car for the past 25 years or so. I had an opportunity and cash to make it mine and I brought her home. It's a fantastic cruiser and many folks think that it's an Impala...
HS
dustinova
Portland, OR
Dustin
C10 Stepside
I got the heads installed and torqued on my LS - should be close to getting it wrapped up and installed in the engine bay in the next few weeks.
Turbo4whl
Downingtown, PA
Wayne
HS
I won't hold that one Ford against you. One of my good friends is a 1962 Galaxie guy. He started with his grandfather's one owner '62. I don't hold the Fords against him either, but we sure do tease each other!
He has several that he brought back from the grave. His current project is Hi-Po chassis. You know, a small production run available to the public, so the stock racers could have a little better unit to beat up on the track. I will admit, I did text him your picture, to make sure I got the year correct. That gave us a chance to chat.
79_GMC_C1500_jj
SF Bay Area, CA
jim
C1500
Almost finished the new instrument cluster for mine.
Hi Guardian, I was just curious, if you're keeping OG bezel, and putting new instruments in there, or if you found a complete replacement unit? I'd like to upgrade the guages I have,... adding a bit more detailed readout than the stock ones. Anyway, just curious, where you landed on that. Thanks, and good luck with the upgrade.
Strick
Dunn, NC
Harold
C20 Crew
Many thanks. Most of my car buddies have really liked it since I got it. A few of them have remarked that I've "switched over" and some asked me if I was alright... I'm a car guy and have many that are very nice and they also happen to be GM. It's not easy finding good Ford stuff (I'll get hate mail for that one) as they didn't crank out as many as the General and they change in the middle of production runs quite often (hence my 63 1/2). I have a 68 Torino GT that I hope to get messing with one year but it is way out on the back burner. It's a rot box in need of much body panel repair/replacement as well as glass and drivetrain. I love the lines and style on that car though but unfortunately Ford vehicle design and function doesn't trip my trigger like GM cars and trucks.
We had family photos made last Fall and I used these two for the backdrop.
HS
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
HS
Love it.
Outside of Mustangs I'm certainly not a Ford guy but there are a handful that I really like the styling on. The '63 Galaxie XL is definitely one of them, but I'm a weirdo that likes the box top over the 1/2 year fastback. The '66/67 Fairlane and the '65/66 Galaxies are also some of my favorites
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
So, I've been driving it and loving to be driving it again even with the intermittent hard shift in to 2nd. I even got to the point where I could control, or so it seemed, the severity of the shift in. Today while running errands it started stumbling just a little while I turned on to the main road from a red light. I immediately headed home on the back roads but made it and the truck was on and off. Once in to 2nd or higher, above 25 mph, it seem to run ok. Stopping and then starting a little stumbling. I parked it in the driveway and decided I would, check the oil that's fine. Remove the air filter and take a look at the throttle body, injectors, TV cable- what's missing?
When I pressed on the cable I was like: " wow that is a lot of slack!" Then I noticed it wasn't connected. I wonder how long the clip has been missing?
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I guess it's not just the clip but the whole end is snapped off? Is it possible to get a new end piece or will this require a new cable? Researching...
gmbellew
Kansas city
glen
suburban 1500
that black thing a few inches past the cable end is the clip. reattach it....quickly.
TV cable is very important to the transmission functioning and not burning up. that's why I asked about it back in post 22,658 of this thread.
Pnew
