That card trick works great, used it on my Jeep wheels and will probably do same on my C15 wheels.
It sure does! I've done it several times over the years. I've learned that with heavy metallic paint like this one, throwing the wheel/tire in a trash bag and cutting a hole works well for keeping the metallic off the sidewall. Otherwise it's hell to get off
Redfish
Prairieville, LA
Andrew
V1500
Boiled Linseed oil or Tung Oil work really nice as a preservative. Roll on a coat once/twice year. Mix with a little linseed based stain if you want a little color. These boards get a little drink on Tung Oil yearly.
Those boards were milled on a circle saw mill. Extremely cool.
And I Love that Truck.
ChuckN
Bellinham, WA
Chad
Got a load of garden boxes from Lowe’s to build for the wife. Took her around town for a cruise. Then back to the garage while I work in the yard.
1STLS1
West Phoenix AZ
MIchael
The floors in my truck had deeply pitted surface rust from sitting with moisture under the carpet for a long time. I had tried wire brushes in a drill, various angle grinder discs and none really did a great job . All made a huge mess and required wearing a dust mask and washing up when done. Cruising the internet, I was looking at Evaporust and other similar items but some suggested using vinegar and leaving it soak. I didn't really believe this but had about a gallon of 30% vinegar left from trying to clean the windows so figured I would give it a try.
I covered the area with a thick shop paper towels, soaked the area with the vinegar and covered it with a plastic bag then went to bed for the night. This morning, I was really surprised at how well it worked. I did not take a before pictures but this should give you an idea of how large the area was.
I am doing a second soaking now to try and get the rest of the rust removed. I am calling this a win
With the plastic bag covering the area
With the bag removed
This is after I cleaned up the towels and rinsed the area, washed and wiped it with a cloth towel. Didn't try using a wire brush or anything to clean it better. The one video I watched showed using various vinegar strengths and showed plain household distilled white vinegar works about the same and is much more cost effective.
WFarm
Central Virginia
K5 Blazer
Shows and Cruise-Ins are starting up here. Went to a local Cruise-In this afternoon. Beautiful evening, temps in the 80s with a breeze.
The blue GTO belongs to a neighbor down the road. I saw him leave today and just knew where he was headin! That 57 Chevy was one of the nicest I’ve seen in a while.
All in all some nice cars and fine folks tonight.
Turbo4whl
Downingtown, PA
Wayne
Drove Hillbilly Deluxe home from school today & I'm more than satisfied with the ride from the 35 Patagonia & Rough Country 6" lift. Those came from a parts '91 Sub that I bought almost 2 years ago. Still have many things to finish but the project is coming together nicely.
Do I see a '63 Galaxy behind that lifted 4x4?
I finally killed the TH350 last week. Time to upgrade so I picked a TH400 up this weekend to have built by a local guy. I only want to do this once so I'm trying to get rid of all the weak links in 1 shot. New driveshaft to be made with 1350 joints and maybe a new converter.
Started today dropping the exhaust and pulling 1 of the headers. Hoping i can slide the trans out without pulling the other. I'm not looking forward to fighting the top 2 bellhousing bolts :mad3:
You "can not" get rid of weak links, only move them up or down on the food chain. There is always one weaker link. The correct way to control weak links is with your right foot, and your left foot if you drive a stick.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Awesome!
Rustisbest
Tennessee
6.1762844 liters
If you say so lol. Nothing else is being done to the engine so the rest of the drivetrain will be more than enough for how I drive it.
I mean I guess i could've left a turd 305 in it and pu$$yfoot around worrying about mpg but that isn't any fun in my book :deal:
drowe14
