Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
no magic. i didn’t tell you it took 4 times painting them. Waiting two weeks before putting them on. Then they still weren’t fully cured and then yesterday this happened from the tonneau cover. Stripped them all the way down,now using an adhesion promoter, and repainting again today.
I feel your pain. :(
If those are metal, I've had good luck with pre-heating pieces to about 80° before spraying, and then cooking them at around 110-120° afterwards.
Baked enamel finish. You just have to be careful with temperature control. You can end up with a wrinkle finish if you're not careful.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Looks great! Did this air cleaner top have a drilled through hole? I have one we found at a swap meet decades ago that has a threaded hole for the carb stud. Of course you still have to trim the stud to fit....
Just a hole in lid no threads.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Need some opinions. Swapped rims to see how it like it. The rallies actually have white letters but on the inside. I'll have them turned out if I decide to go with them. I really like the rallies but they are about 3 inches shorter than the others. So that will raise rpms on highway and now has more fender well space. But I do like that the back tires are wider than the front tires. Kinda torn more than I thought I'd be. Thought it'd be rallies all the way. Hence the reason I bought them. Lol
Maybe once the white letters are out it'll make a difference.
I'll have to drive it with them on too to see how it like it too.
I'm no help, I like both.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I know huh. That's why I'm so torn. Lol
mxer147
Colorado
Jack
k20
Sanded the hood, epoxy primer again and the two more coats of high build primer. Also sprayed the tailgate handle and fuel door.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
In the process of smoothing out the firewall, commonly found in the rain trays water dirt like to freeze in behind the seam sealer and create a few weak spots easily punched through with a flat screwdriver - lead me to a question - where does a guy get new AM firewall grommets for the wiring/ cables/ harness - or is it going to be all at the wreckers?
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
they are plastic. i’ve shot them again today. looking good. going to give them a month in the sun before installing them.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I like them both but I am definitely more of a fan of the rallies.
SirRobyn0
Well it's been a while. Most of you probably know I've been up against some life issues and while there is still a lot up in the air I'm trying to get back to doing the things love. My square has been, parked since last September. So we had a nice stretch of weather this weekend so I started it after changing the oil and giving it a good looking over. She fired off on the second try. Not to bad for all that sitting!
Took her for a short drive and then did a big clean up inside and out scrubbing the truck down and making it respectable again.
So I didn't really accomplish anything on the list of things I'd like to do on the truck but shes back to operating status and gonna see the road again!
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
I think they actually made them both ways. One I have is Cal Custom and it's probably from the 70s. It's going on an old truck I have (older than squares and definitely won't be stock when I'm done with it).
Camar068
10 yrs Air Force
Burped the LS coolant. Temperatures are about 195° now. Was hitting 210° before. I did this by taking the top radiator hose off and raising it up about 18" then filling until water started coming out of the radiator, slap it back on.
Tonimus
Phoenix
Tony
C10 Suburban
Tightened the valve covers, new 94 amp 12SI alternator, all new v-belts, new headlight adjusters, aimed the new LED headlights.
Domarinolo
