mcarlo86
ND
Suburban
Redfish
Prairieville, LA
Andrew
V1500
@JamesSam I posted in our PM but for the rest of you, I am going to try to get a couple cell phone videos so he can hear my fuel pump priming prior to engine start and then see my injector spray pattern with the truck idling. That may help or may not...
Not set up to post videos on the forum...
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Yes, I read the stock actually does 18psi. I can't see us needing that, but understand the concept of having more psi, then adjust our regulator. I feel like 60 psi could be extreme for our build, and possibly dangerous. I may be fixing to drop tanks. RH made truck studder previously. Right now, no fuel to TBI when we started up. LH pump runs, just code 12. So gonna start with the lines, filter, and valve. Need to see if LH pump moves fuel. That was lengthy...but it is very in garage with heater.
I really need a garage space for my truck so I can begin doing the same.
by the looks of it my dad has been driving it around without plating it... that plate from the previous owner would have expired in 2009 lol
So yeah my dad got a ... 1978? 1977? C35 dually
454 and th400 presumably (its auto, so i presume th400)
I think this means its a dana axle because i dont think they did the 14s yet like this?
Ajax19
Socal
Ajax
Should be a 14bolt FF(full floater) 2 quick ways to check count the bolts on the diff cover and if axles are bolted on it's a FF
legopnuematic
Licensed Junk Dealer
MO
Spencer
For a 77 or 78 (ish) DRW truck should be a Dana (70hd I believe).
From the 1978 vehicle information kit.
ChuckN
Bellinham, WA
Chad
Out in the garage. Found a whole bunch of surface rust under the door frame weatherstripping. Went after it with my corner sander, and the drill with a plethora of different wire wheels, then applied some Eastwood Rust Encapsulator. I’ll eventually get her painted but this will save on ‘er for the meantime.
Regular duallies with a truck bed got the wide Dana 70HD model. Cab and chassis models (no bed) got the 14ff, but with a narrower track width than even the single wheel trucks with a 14ff.
Ajax19
Socal
Ajax
For some reason I thought they mostly used 14bolt in the civilian trucks and usually d70 in the cucv variety Id still count the cover to be shure I wouldn't necessarily trust the book because my 75 srw has a 14bolt and so does my 83 drw cab and chassis truck that has 11k gvw not Shure about the regular dually check the cover it's easy and best way to know fershure
Is the 70HD good? I wonder if it has the pinion support like 14 bolt.
Also
So from the looks of it, my dad got lucky on the wheels being one piece and not having the ring?
Also
It doesn't have the bolt-in pinion housing, no.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Throw a link up to a YouTube video/ make a instagram and post a link to that also, just thinking
Tank6x2
Kurt
C30
Bullet proof thus far
Also
On the truck or off, 3rd / 4th photos are definitely widowmakers
chevelless07
