JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I finally decided I would try a few more things before handing the truck off to the garage, and I would have to tow it in anyway. Picked up new: IAC valve, O2 sensor, and ignition coil. Just to see if anything would happen differently I put the IAC valve in. (Keep in mind I just recently replaced the TPS.) Started the truck and it was idling high and I was kind of expecting that. I let it warm up a few minutes then mashed the gas a few times and there is no stuttering in park which is an improvement. So it seems to be getting good balance of air and gas/ not bogging. Now I guess I need to do the paper clip tune up trick. If I can dial in a good idle I will definitely be replacing the Ignition coil l, unless the current one is looking great ( haven't checked yet), and the O2 sensor. I realized I forgot to look for an ignition module while at the parts place. Oh, I found the IACV, O2 sensor, and ignition coil all in one spot, the Advance around the corner from my house.
Let me know what y'all think. Feedback.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
I know on my Vortec OBS trucks with 5.7s, the TPS and IACV often go out in sequence. Now my trucks, unlike the TBI trucks, don't need a relearn procedure for these sensors. But both of them ran better after they were replaced; in both cases, replacing the original factory installed pieces.
Ajax19
Socal
Ajax
Keep at it man eventually you will find something awhile back I had a random sputtering and it was a combination of things one I had the original cap and rotor the rotor exploded and I didn't get all the bits out of the dizzy and there was a chunk of metal from the old rotor bouncing around in there ontop of that I decided to replace the coil and the new coil had longer wires and I pinched them when I put the cover back on lol
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Doing a little research. I need to get my hands on an auto meter for setting base idle. Then I will need to adjust the timing in the TPS. A few things I read about not trying to adjust the torque screw for timing, people having bad experiences trying to adjust the idle screw themselves. I really want to do this right the first time.
Rustisbest
Tennessee
6.1762844 liters
Got the bluetooth amp wired in and it sounds better than what I had in there so I'm happy with it. Without the AC ductwork in the way I had plenty of room to mount it behind the dash cover with 3m tape.
Rustisbest
Tennessee
6.1762844 liters
Just a shot in the dark but check to see what the coolant temp sensor is reading if you can get a scanner.
May be reading low and trying to run the idle high and at a richer mixture to get the engine up to temp.
ChuckN
Bellinham, WA
Chad
Not much happening today. Just picked the kid from school in the truck, drop off at Tae Kwon Do, then a fresh tank of ethanol free on the way to the water for the sunset. Too many cars for a picture in front of the water, but a nice chilly (and dry!) evening for a cruise.
Ajax19
Socal
Ajax
It's not much but I did get one side drilled out have to get a few longer bolts and some washers it's not perfect but neither is this truck lol I'm going to have some free time tomorrow I'll get some decent progress then
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Should I be adjusting the torque screw in the throttle body and adjusting the TPS for timing or should I disconnect the timing set bypass and start at 0? Although I have not done anything with the distributor. No messing with the pickup coil or dizzy yet.
Ajax19
Socal
Ajax
Other side bracket getting the holes drilled out made some funny looking notches in some leftover 2x3 tube to see if my idea works to brace the section of 2x3 that the gooseneck bolts up to tie into the main 2x3 that runs along the frame I think it's necessary to keep it from wanting to twist nothing fancy just beefing it up
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Roger 15. I didn't feel the need for a 60.
Also, did you upgrade your fuel pump(s) or keep stock?
Redfish
Prairieville, LA
Andrew
V1500
I know you are trying to fix a problem and not trying to enhance performance but you can get a noticeable improvement if you set that timing a little above 0. Mine was a little above 8 degrees until I had to set it back to 0 for my chip.
Just occurred to me that I got my chip from Brian Harris in W. Virginia. You are a lot closer to him than I am, you might try reaching out to him.
Chevrolado
McKinney, TX
Dave
K10/1500
Here I thought the hardest part was just getting the dang ol oil pressure gauge hooked back up.. Yet somehow my whole cluster is not fitting in back in the dash. What am I missing here.. Sheesh. It's like the whole housing hits on top and bottom edges.
You gotta hold your tongue juuuust right so it will go back in place. And maybe squint a little bit too.
ChadwickPNW
