This was an unexpected issue getting the truck ready to go back on the road that I had not encountered before. This was a truck I purchased off a board members friend in upper Northern CA a couple years back. The glass was stained with waterspots. I mean so bad I had to drive with the drivers door open to see forward. Tried CLR, industrial vinegar, rubbing compound, etc. It was better but still had marks and scratches. Thought about it and how long it was going to take only to get marginal results, bit the bullet and purchased all new glass for it from a local glass shop who I had coming out to put a windshield in another vehicle. I had previously purchased a complete weather strip replacement kit that included the front and rear gaskets so already had them. Ordered a pre cut tint kit for it too, here in AZ it's a necessity.
Sounds like crazy water spots. Did it somehow etch the glass?
JeffK10America
Easley sc
Jeff
Guess I’ll join the swap your radiator club. Last winter when it got down to -20 degrees the radiator in my CUCV froze and split. I pulled it out and soldered it, and thought it was good, but it started leaking again this spring. Never one to do anything when it’s easy, I waited until this week when we are expecting snow to fix it. Found the leak in a different spot than before and soldered it up. Appeared to have fixed it, but I didn’t have a way to pressure test it. Filled it up and tried it out today, and it appears to be leaking again.
Thinking about buying at new one since the one in it is probably original and will probably keep springing leaks. Looks like prices range from about $300 on Rockauto, to $550 at Autozone. Any recommendations for a decent brand?
Bought mine for a 1985 K10 from speedway motors about 2 years ago 3 core .... was 399 then , who knows now with bidenomics !
1STLS1
West Phoenix AZ
MIchael
Once I get the film or what ever is on there off, you can see water spots etched into the glass. After a couple minutes of trying to polish the glass, it has very defined light scratches and you can still see the water spots. Acid rain? That was a big thing during that era. I remember cars having their paint all screwed up by it.
Now, it's never going to be a 100% restoration but a fact about Phoenix, the roads run North to South or East to West and it's flat. You end up driving into the sun and a hazy glass makes it worse. All the glass including the windshield, side windows, vent glass and a solid rear window delivered to my house was $380, ceramic 3M pre cut tint was another $225. I didn't think it was that bad, I expected it to be more.
Camar068
10 yrs Air Force
did someone use Purple power aluminum brightener on anything near it? I used that on the aluminum on my camper top and it got on the glass. The directions specifically say not to use on glass. I've now got a haze/etch where it ran down.
Just in case, I'll run thru the brain (lol) and chemicals I think I used on it prior to painting to verify. What ever I used, will not come off period. I tried polishing in a small area with no luck. With trying to shine up the aluminum on it, I'm 99% sure it was that product.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I dropped off the other radiator my neighbor gave me because it's in better shape than the other one. One last try at it before I buy a new aluminum one. I'm gonna leave the fan shroud off this time to see if that makes a difference. Because I don't remember it leaking until I rigged it to fit. Probably end up putting electric fans on this summer. We'll see how it runs.
sidschev
Arkansas
sidney
c1500
sounds like sand etched glass. sand is horrible on everything. from arizona wind blowing sand ect.....
1STLS1
West Phoenix AZ
MIchael
The windshield I just replaced was for that , this place is tough on glass that way. The stained are little water splatters all over the glass. I will try to get a picture of them. Most people would just send it but as I said, morning and evening, your directly into the sun, it's hard enough to drive at that time.
1STLS1
West Phoenix AZ
MIchael
I only used car wash soap the only time I washed it so not to take off any more paint, but yes Purple Power is my go to degreaser and cleanser. I am familiar of what it can do
using it too strong.
hoagster
California
K10, 1500
5.3l
Well that truck sat in that spot we moved it from for a long time, in weather from freezing to blazing hot. We regularly get 115 in the summer which rivals the temps you see in the Phoenix area. I happy that you're getting it back on the road again. Looks a lot better.
Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
I’m a big guy (6’4” and 350ish). And my bench seat was a bit high and forward for me. So today I modified the stock sliders. They are fixed position now but the seat should sit about 2” further back and an 1-1/2” lower. Pretty much the hinge cover on the sides will be right on the floor of the cab.
Pics are of one stock and one modified to show the difference.
Travlr
Central Utah
C
K20 Camper Special
So they no longer slide? Not adjustable?
Drauka99
C-10
6.0 LQ4
Nope. To get the seat lower all the adjustment stuff had to go. After the engine swap it became very clear to me that I wasn’t going to feel safe letting my SO drive the truck or pretty much anyone so seat adjustment became pretty much a moot point from there
WFarm
Central Virginia
K5 Blazer
Installed a couple of parts my wife got me for Christmas. The front air deflector had been damaged at some point. New one looks much better although it took a little whittling to mount it as a few of the bolt holes were off a little.
The dome light never looked right although it worked. When I removed it I saw why: The base had melted! The new LED bulb should prevent that from reoccurring.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
That's half the reason I switch everything to led. Looks good!
dannyphx
