78C10BigTen
pennsylvannia
C10 BIG TEN
I repainted the grill and headlight bezels, and bolted down the emblem properly yesterday.
Today i installed my new/used hood latch cable. Works great. Also I realized it wasn't "popping" up like it should, and realized why, i fogot the hood pop spring. So now that works. Adjusted the hood so its straighter and level with the fenders, and put a stack of 2x4s under one side and layed on the other to get the tweak out of it. Lubed everything, and now its a perfectly straight and perfectly working hood, with no dents, yaay.... and terrible paint.
Also decided to try to attack cleaning up the wiring, which ended up leading to gutting the interior. Got all the bad wiring cleaned up, got the wiring and brackets for the radio and CB that the PO had and removed before me. Also removed the trailer brake assist box, braket, and associated rats nest.
Removed the badly smashed ashtray door. Removed the destroyed rubber mat and insulation, and cleaned the dirt and nasty out. Happy to find out that the floor and weather channels are solid as a rock and rust free.
I think tomorrow ill scrub the inside clean, clean windows, and ill probabaly paint the whole floor with some rubber bedliner stuff i have. Do away with the mat.
Get ridda da red!!! Lmao!!
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Oh i plan on it. I dont like red trucks.
Theres not much left of the red, just the cab.
I want to paint it the dark metallic silver that the insde of the doors are. Thats one of my favorite colors.
Camar068
10 yrs Air Force
Recovering from the locked up LS, I've got the hood, grill, bumper and minor wiring clean up to do then she's on the road again.
Camar068
10 yrs Air Force
Keep in mind I pulled the whole front clip to do this. I'm going to look at having a forward tilt front clip. That or next time remove it whole.
Finkaire
Finkaire
California
Loren
Silverado c10
Trailer hitch, went on without a hitch, haha
hogdaddy
Alabama
mike
Scottsdale
Getting ready to get these Speed Hut gauges installed soon. I modified a reproduction gauge bezel by cutting/grinding down the plastic pods in the back so they would flush up to the backside of bezel. Mounted the gauges in an earlier metal style back piece after enlarging the holes.
Been saving a nos dash pad for years to go along with it.
These will sit in the stock green plastic case and install as oem too. Finally, will get accurate GPS speedo.
FireTruck1984
Michigan
1984 and 1984
Getting ready to get these Speed Hut gauges installed soon. I modified a reproduction gauge bezel by cutting/grinding down the plastic pods in the back so they would flush up to the backside of bezel. Mounted the gauges in an earlier metal style back piece.
Gauges look great! That’s a slick custom installation, I’ll have to steal that idea
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
How much did that setup cost? I like that so much, i want one, lol
hogdaddy
Alabama
mike
Scottsdale
I believe it was around 1k but modifying those panels took me a long time.
Cutting into that new $$ repro gauge panel was scary plus I used a hand file on it lastly.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Ouch..
But beatiful
ebodell08
Iowa
Erik
Got her moved over from the north shed (dirt floor) to the big shop (across the road) and changed the oil and filter and lubed it.
Weather has been mild the past couple of weeks so I have been doing a little truck work. Also been noodling on the '67 and I moved the '93 over to the big shop as well so I can do a little PM on her as well.
WFarm
Central Virginia
K5 Blazer
Removed my factory bed rails and sent the 4 end pieces off for re-chroming as I have not been able to find NOS or repro pieces. I had previously painted the wood grain black as I never thought wood grain went with the rest of the truck.
FireTruck1984
Michigan
1984 and 1984
Hi Paul, I restore and sell Show quality Bed Rails. Let me know if you need anything. PM me
WFarm
Central Virginia
K5 Blazer
How do I PM a member Firetruck1984?
goodwrenchca
