- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
That’s why I hard mounted a 5lb fire extinguisher in the bed!Chuck n #16419 Grit dog #16423 I've seen more than 1 car burn from fuel lines like that. Just trying to help. At the very least run as much hard line as possible with very short rubber lines as connectors. Like the plastic tube rubber connector vacuum hose arrangements.And I'd run a metal fuel filter,down low, so A leak would be under the truck instead of spilling fuel on the motor.
No, I understand your warning 100% and agree with you. It’s one of the few things that got hack jobbed when whomever put the big block in it.
Coincidentally I just learned approximately when that engine went in it and it’s been like that for around 15 years now!
Regardless, it’s also on the list to redo with a safer fuel line setup.
