AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Picked up the newest member of the squarebody family today. 1987, custom deluxe K20 (V20), TBI 350, sm465, nice ranch bed, a free set of 8 lug rims, and a bunch of new parts in the cab. Not even the tiniest spec of rust anywhere. $800.
Runs and drives, but the power signal to the injectors cuts out randomly, so I'll probably swap in a carburetor instead.
I also have sitting at my house, a set of nice doors, nice fenders, a nice hood, a new grill, and new rims and tires that I'm going to probably throw on there to clean it up a bit.
Might just need an ignition module. They can take out injector pulse when they are failing.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
You mean there little module in the back of the distributor? I changed that out on this truck already.
I replaced the fuel pump, fuel filter, fuel pressure regulator, fuel pressure sensor, fuel pump relay, ignition module, and replaced the injectors with a set out of a running TBI. No luck.
Sometimes itll start up and run great for a little while, then without warning, itll just die. And I've watched the injectors when it happens. One minute they're spraying, then they stop, then the engine dies. If you bottle feed it, itll stay running.
After all that, my boss just gave up on it, so that's why I bought it. I know I can just throw a carb intake and a mechanical pump on and solve the issue. But if you have any insight to fix the TBI, please do..
Yep, sounds like it's troublesome, lol. Do you have another ECM to swap in for a trial?
gmbellew
Kansas city
glen
suburban 1500
maybe the ECM is bad? I don't think that is very common, but sounds like you covered a lot of bases already ....
yeah, what Bucket said! too slow on the response here....
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
No, sadly I dont.
Have a ECM out of an 84 Corvette for a crap-fire injectors, haha.
I figured that had to be the last option, cant think of anything else.
WFO
Texas Panhandle
I had to put a new Delco ignition module in my truck the other day.
Been drivin cars and trucks with HEIs for 45 years, and this was the first one to give up the ghost.
Someone before me had put in an Accel module in it.
CRM
Pasco, Washington
Casey
K2500
350 CI
Got a lot of parts delivered today. Installed the new tail light assemblies, mirrors, tstat, and tstat housing. The gauge lens showed up broken and the air filter showed up crushed. Cleaned and painted the air filter housing.
Ken B
indiana
ken
I got new window motors to install. I am going to clay mitt the glass before install.
Any seasoned vet have any helpful hints on reinstall of window regulator and motor...
justhorns
Denver
Lee
Original seat coming out for new foam and vinyl. 42 years of wear and one crappy cover. Anybody want the Carhardt cover?
1STLS1
West Phoenix AZ
MIchael
I would verify powers and grounds. I would have a test light on the tank pump to verify it's powered when it's cutting out. Then the distributor. Clean and check all the grounds are attached, to the core support and the frame along with the back of the head. Do a shake test to the harness while it's running. I have been wrong dozens of times in the past but generally if it was an ECU, it works or it doesn't.
CRM
Pasco, Washington
Casey
K2500
350 CI
Morning session:
Glued down the floor liner and set the mat down. I won't make the mat permanent yet.Temporarily installed the rear speakers.
FireTruck1984
Michigan
1984 and 1984
That original material and pattern is Great ! I hope you have it Upholstered with the original design.
Ken B
indiana
ken
today I reinstalled drivers door motor regulator and glass..pain in the A$$. reinstalled steering column, plugged in wiring to column, reinstalled wiper motor until,,,,the last screw , last "snug" the SOB snapped....3 steps forward and 1 back. Odd screw big head and small screw, might be tough to match/find
Doug Hampton
