Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
What the hell kind of stew was in there? Lol
I have no idea, but that **** looked disgusting. Thats like, the original fluid or something lol
Vbb199
Salisbury NC
Vince
Well, this evening, about a total of 5-6 hours was spent on my rear end, and there were numerous debacles.
1. Original Carrier bearings were STUCK STUCK STUCK! The first one came on after ALOT of struggling with the seperator. The second one just wouldn't come, AT ALL, not with a torch, not with a big breaker bar on the puller, not with a impact, NOTHING.
I had to use the side grinder and cut the frame and take a chisel and hammer and knock it off!
Removing carrier bearings alone took me a whopping 2.5-3 hours WITH the proper tools!!!!!
THEN, the pinion nut that came in the set had/has a damaged spot in the threads.... it wont even go on the pinion...
so using the old one, which is sorta damaged, im having to set my pinion bearing preload by rotational "feel" rather than the 15-20 ft lbs needed. That makes it a ******* PIA
old Pinion bearing popped off easily in the hydraulic press. By my estimate, i have about .01-.02 to take out of my pinion depth, and a tad bit of carrier shimming and i will be set.
What a debacle of an evening.
CRM
Pasco, Washington
Casey
K2500
350 CI
Real tough repair today....Lol...replaced the glove box bumper stops. Got tired of hearing the banging sound when closing it.
Vbb199
Salisbury NC
Vince
Done and done.
Backlash is supposed to be .006-.01, I'm at .005-.006, the engraved number on the ring is .006, I'm fine with this. I'll be driving the **** box later today.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Done and done.
SO exactly where do the pedals attach?:party52:
Vbb199
Salisbury NC
Vince
Im ****** pumped to try these 4.10's out. Shes already pretty ****** fast and torquey with 31's and 3.42's...... this 4.10 setup is gonna be BADASS
Vbb199
Salisbury NC
Vince
Ohhh come on man, put it in the red. Then you can start the 500th thread about why your not getting 100MPG! LOL:party52:
Ha! Aint that the truth
Last i checked before a tune up, and sensor replacement, i was getting 14 on the highway, its probably much better now, but with the 4.10s, i will probably see better town mpg tho.
Vbb199
Salisbury NC
Vince
Naturally, i had to brush up on my drum brake assembly skills again haha
Vbb199
Salisbury NC
Vince
Got the axle dropped back in, waiting on the wife to help me bleed the brakes.
This is gonna be a problem however.. tires immediately started spinning in the grass with the motor idling
We did have a downpour yesterday, which doesnt help tho.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
If you get it on the road let's see a burnout :burnout:
ESONE
