Got about 70% of the wiring done tonight. Been putting this off forever and dreading it. Really wasn’t bad, I just had to stop looking at the whole picture and just focus on one circuit at a time
Sent from my iPhone using Tapatalk Pro
what is the wiring for? running stock efi or is it some after market? thats a lot of module and connectors for the 80s lol. Or just because you are running a modern system you just wanted to get it all knocked out of the way, nice, clean, not-cut-up, wiring that will prevent issues for years?
The wiring is for the LS swap. Used a PSI Integrations harness and now I’m working on tying it into the original truck harness and out into the engine bay where the distribution blocks and relays area
jjester6000
Illinois
Jack
C1500
First there was Bambi, now I scraped a tree while trying to tow a non running vehicle around my property
That poor bumper.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Suburban got a small upgrade. A tach.
Also replaced heater core today... which turned into a debacle of piecing together 2 heater boxes to make 1 good one, and gluing together some broken plastic.
But i have heat again!
(Winter is approaching , and my wife and kids gets rather cold when it drops below 50)
Im in the minority in the effects of cold.
My performance chip was ordered, so im just patiently waiting on that
1979k10
Nevada
Dave
New speedo, speedo cable, cluster lens, bezel and dash pad. I caught a case of the might as well as I was doing the speedo cable. Oh and all led lights in the cluster.
CoggedBelt75
Oklahoma
Joe
I know it’s an Eveready but I think it may have lost it’s charge
CoggedBelt75
Oklahoma
Joe
Knocking on wood, I haven’t had to do anything except turn the valve on for the water to flow thru the heat. Supposed to be 41 when I go to work in the morn.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
Swapped a 12 bolt into my 88 burb with a flip kit. Now struggling with shock extenders. Come to find out, the rear end must be out of a 4x4 and had different shock mounts... Who knew. Any ideas for shock extenders that will fit?
Same problem almost 10yrs ago... http://67-72chevytrucks.com/vboard/showthread.php?p=8824206#post8824206
Sent from my SM-N986U1 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
Why way DA FOOK down there?
Vbb199
Salisbury NC
Vince
I couldnt find a suitable location anywhere else and i wasnt alright with a column tach.....
Too...... old manish
Doug Hampton
