80BrownK10
Greenwood, SC
Nate
But, I've had a flex fan that *** equally spaced and sounded fine.
The flex fan I had sounded like a turbine and the truck was about to take off. I pulled it , sold it and went back to the clutch fan setup so it won't Rob what little power I have while driving over 30 mph.
85squaredC10
Wisconsin
Jason
Since you mention it, it's very rare that I can distinctly hear the fan in my truck. Granted, that noise and vibration factory under the hood may have something to do with that. All that being considered, I don't need anything to contribute more noise either.
But the times I do remember distinctly hearing it have been when the alternator belt broke and wrapped itself around the fan clutch and locked the fan to the shaft. You could sure hear that.
Maybe there's something up with your fan clutch?
Thanks for mentioning that. I'll have to check it out. Any advise for testing good/bad? Much appreciated. Side note: mine was new 2 years ago.
Sent from my SM-G965U1 using Tapatalk
80BrownK10
Greenwood, SC
Nate
I hear it badly on my '90 GMT 400. That thing whirs like crazy going down the road at speed. I chock it up to short tires, 3.73's and no overdrive.
Fan clutch could be locked up. On my old ranger the clutch locked up and it would roar loud like it was going to take off.
It actually seems to be working properly. It's just the large big block fan and a decent amount of rpm. Electric fans are on the agenda.
85squaredC10
Wisconsin
Jason
I am also looking into getting electric fans. Can't decide if I want one big fan or two smaller fans. Any thoughts?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If it's only two years old it's unlikely that it's bad. I usually check that I can turn it by hand when the engine is off, no leaking fluids and that it doesn't wobble. Maybe if it's hot and idling you'll hear it engage.
Maybe like bucket your problem is just high RPM and a Big @$$ Fan.
85squaredC10
Wisconsin
Jason
Sounds like I need a louder exhaust and a better stereo!!! Lmao
Poppy 87
Bloomingdale GA
R10 Silverado
For what it's worth, the late model trucks use dual fans. With a combination of 3 relays, can actually switch the fan speeds depending on demand.
Sent from my XT1254 using Tapatalk
Auburn, Washington
New drag link. Make old truck drive like new one! (sorta)
Best part was old one popped off with (relatively) little effort.
Napa had the parts in stock AND I was surprised how reasonably priced. Less than $50 for 2 new end links and got to re-use the adjuster!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Started trying to remove the headlights and get ready for the new ones. The po put some really ****** sticky black **** all over them. I guess to hold them in. Idk. But, this is gonna be bitch I'm afraid.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Those gawddam plastic little deals the adjuster screws go into seems like was the real problem child on that '91 I had. And, of course, since there a 4 of 'em, twice the fun !
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
45tt
Florida
MJ
GMC Sierra Grande K15
Changed out the KC light covers for something different. This’ll allow me to turn the lights on without taking the covers off first. The red covers are a hard to find item anyway and I don’t want them to blow off driving down the road. New covers fit good (snap on), turned on the lights and one didn’t work. It came on after jiggling the wires, so I guess I’ll fix that tomorrow.
The88
Mhmm
South Louisiana
ThatGuy
I have been tossing up getting a few KCs. Presently I have 2 sets of led recess square pods. I would have to cut my front bumper to install them so I am tossing up if I will use them or bench them and buy round.
45tt
Florida
MJ
ive had the 6” rounds on a few of my Squarebodys and they’ve always worked out well and I like the period look. Only problem I had was a clearance issue With the garage door when I had them on a roll bar and the chrome always needed polishing to keep the rust from creeping in. I did notice they have black painted ones now that look nice and require no polishing.
brentjo
