TubeTruck
East TN
Denis
Suburban K10
LQ9
It was miserable! Rained all day, i was soaked through winter coveralls and insulated pants to my underwear. I was workin in a huge puddle. I learned nothing, couldnt find the culprit. I used to have a sticker that said "i miss my ex but my aim is improving" lol
Same with me. Snowing all day but it was 38 and everything was melting. I was soaked!
I will say one thing about your rear. That pinion is reeeeeaaaaaly worn. It's lived a good life.
78C10BigTen
pennsylvannia
C10 BIG TEN
Didnt look like that when i put it in... pretty sure i made it fail
eskimomann209
Modesto
Marcus
Making me worry about my 47 year old gears now!!!!
Ken B
indiana
ken
question....doing body work on my 81 stepside, I pulled the inner fenders,,,swiss cheese! I want to know if I can pull the front clip and leave the radiator or if i do pull , will it all come as a unit?
78C10BigTen
pennsylvannia
C10 BIG TEN
Yours should be good. I just tossed the posi in with all the same shims and stuff, didnt check the mesh or anything. Then the pinion seal blew and i neglected it and ran outta oil. I pretty much set it up to fail.
80BrownK10
Greenwood, SC
Nate
Will have that bigC10 back running in no time.
eskimomann209
Modesto
Marcus
Had to order a new rear line to the diff
78C10BigTen
pennsylvannia
C10 BIG TEN
Heres a note to everyone doing a rear swap... if you buy new u bolts always check they have nuts!!! The ones i bought didnt have them and 9/16-18 nuts are a MF to find!!!
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Well here we go again.
This a parts swap or are you planning on running two different bolt patterns?
Also, what kind of truck is hauling this? The visibility out the rear window doesn't look very good with all that black plastic window frame happening.
78C10BigTen
pennsylvannia
C10 BIG TEN
Yes im plannin 2 diff lug patterns until i convert the fronts later and its in a 2013 gmc sierra.
Jimc21NC
