Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Yup wire fell off.... over a week i been dealin with foggy icy windows with no heat! Glad it was simple. Had it not been for @Arkansas_V8 tellin me to hit it with power straight from the battery i probly wouldnta found the power wire not attatched
Glad it was simple man.
SDJunkMan
Black Hills of South Dakota
Jeff
CUCV won't start, just clicks. Trying to sort out the wiring, but it has a unique 12/24 volt system. Found a couple of spliced wires that weren't spliced very good, and tried to solder the connections, but I think it is too cold out for my soldering gun, or the soldering gun isn't big enough for the wires (10 or 12 guage).
Ran out of time today, have to get ready for work. Guess I'll hit it again tomorre.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Put it back on, drill a small hole in the middle and put a cotter pin through it. You'll never have that problem again lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Well as an update it quit again with the wire on, seems its kinda melty in the plug. I may be splicing on a new plug
Poppy 87
Bloomingdale GA
R10 Silverado
Sounds like a short in the motor. Perhaps the reason it was left unplugged?
Sent from my XT1254 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
No it wasnt left unplugged... its always worked but suddenly it fell off.
Poppy 87
Bloomingdale GA
R10 Silverado
Okay, a loose connection can cause high resistance, thus overheating that connector. I would splice in a new connector and test the circuit for short to ground PRIOR to operating the motor.
78C10BigTen
pennsylvannia
C10 BIG TEN
How would i test that?
Poppy 87
Bloomingdale GA
R10 Silverado
Though I still believe that the motor is the probable root cause, it's always wise to verify that electrical system integrity is correct so one doesn't ruin a new component that good $$$ is spent on. To check for short to ground, connect 1 lead of your dvom to ground ( battery negative works best), set meter to Ohm, disconnect other end of circuit (in this case blower motor control) and using the other meter lead, probe both terminal at the motor end of the circuit. If you measure any continuity, you have a short, if not, motor is the fault
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Tweaked the timing a bit - maybe a hint of clatter at WOT, so I may be a shade too far.
I will keep my ears open. :p
It is probably around 13 or 14 BTDC (off the scale, LOL) but my setting was in park, so probably not as extreme as it sounds.
Running regular now after the EGR, so that helped.
Knoxville
Bradley
Scottsdale
I6
Installed the old mans cb from when he was a trucker in the 80’s in the dually can’t believe how many are still on the handle and still crazy as ****. Firestick antennae sticks up almost 9 feet. Holes line up for the bracket from last time a cb was under the dash.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Start simple. Crimp down that female connector with some needle nose plyers so you get a good connection.
350 w/203
That's too high.
j69shep
