animal
Lee
c10 silverado
350ish
Squirrels...? :005:
Yes. Squirrels. Cob is required to have at least one of the mentioned items in EVERY PICTAR. The only allowable substitute is a pothole. Although as @bucket pointed out there was a trashcan. We may have to make an exception this one time.
73c20jim
Tombstone, AZ
Just to catch everyone up with my progress, I have done nothing for several weeks now.
It sits with a half installed floor panel, seat removed, dash gauges in a pile on the floor (3 sets), no door key locks, Q-jet (sorry I bought it) not working right, AC not working, wrong radiator and shroud (I got the right parts to install), and ambition waning.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
It happens to the best of us
You are honest with yourself at least, lol.
350 w/203
Thanks for the update.
Sit back and admire what you've already done. Plan your next step. But first, have a drink!
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
Have not had much time to play but put in a couple hours this week digging down to the turn signal assembly. Had a bit of rust in there some of which had made a home on the splines making the quickie steering wheel removal into a time eating thing.
What I thought was just some surface rust was not horrible but more extensive than I was expecting. No Idea how that happened (PO spilled water into the wheel?) but the contamination was restricted to above the lock plate. The effected parts got a Evaporust bath and the splines a bit of wire brushing. A coat of Nu Finish polish and all will be serviceable again.
I will see about replacing the TS assembly later next week and hope that solves the D side brake and turn light problem. If not, it will be time to track down a rear intermediate harness to replace the one a PO hacked up for what appears to be a plug-in for a slide in camper. The RIH is on the list anyway as the PO re-routed it so it lays on top the D side fuel tank and the splices are dodgy.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Mounted up the rear shocks and panhard bar on Stormin Norman Tank just have to polish off the welds and clean up any of the high points on the welds to remove any chance of Notch effect to the welds. Should be a fun day!
Doc_Ellis
Nashua, NH
Keith
Sierra 1500 shortbed
It happens. Try not to get too dejected. My trick is to not let a stalled project get completely stalled. Try to do something on it at least every few days or even once a week; no matter how small or insignificant it might seem.
Even if you only turn one bolt in a session, that’s a bolt that wasn’t turned the day before. Sometimes that’s all any of us have time for; sometimes we do have the time, just not the motivation.
I find a lot of the time when I go down to the garage to “turn that one bolt” for the day, one bolt leads to two, which leads to ten, which leads to an entire operation getting done; or at least biting off a bigger chunk of it than I had planned on.
I don’t allow my projects to become chores. And if they’re still unfinished by retirement, at least I know I’ll have something to keep me busy.
Camar068
10 yrs Air Force
I'm sure thats gonna look purdy when your done with the axle.
Dropped it off to have the gear changed to 3.73 w/carrier and hub bearings replaced as well. Can't wait to get it back!! I'll have to have the gearing changed in the PCM on the LS....and the gears on the speedometer module on the transfercase.
78C10BigTen
pennsylvannia
C10 BIG TEN
Snagged this custom homemade steel hitch plug from work that someone scrapped so i popped it on. Funny to note my GMSB decal can be seen in this pic.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That hitch should lower your mpg by1 more. Lol. I like it. Nice sticker too. Wish I had one. Lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Its not as heavy as it looks. Think its about as heavy as the tongue and 2" ball i had on it. But since it got thrown out i thought id give it a new home. Maybe later down the road the original owner will see it and recognize it lol. As for the sticker... hit up @bluex thats who i got it from
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
If you swab it, you may be able to identify the original owner. His dna is probably all over it from obliterating his shin on it repeatedly.
At least I do when I have my hitch in the receiver without being hooked up.
It never fails, I’ll walk to my bed to grab a tool, turn to walk back and bam—instant curse word factory.
It is cool though!
Carb'ed Vortec 350
.........She still wants me to sell it. I can get another wife, but not another 1973 GMC Jimmy Sierra.
Why doesn't she understand that?
Signed,
Running Low On Medication & Money
I feel your pain... :favorites13:
GorillaHumper
