84 C20
Dallas, Plaestine, Gun Barrel
scuddy
350 sb
got the TH350 unbolted and learned that transmission fluid comes out the front, the back and the dipstick side.
put on the new flex plate with new bolts, jammed in the new output housing seal, cleaned up what I could and got the trans bolted to the engine. bolted up the first of three tc bolts and tried to spin the engine.
got the wrong @#$@($%&#$@(*#@&*($%*(@!!!!!!! flex plate bolts. stupid things are too long and effectively lock the engine. so tonight gotta undo everything I did last night and start over.
length shouldn't be this important!
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
At Discount now - these look freaking HUGE !:eek:
The Falkens I looked at are also here.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
The skinnies on her now:
78C10BigTen
pennsylvannia
C10 BIG TEN
Theyre gunna look awesome!
silverscottsk10
trafalgar indiana
mike
Yup, it's quite a pain to find bolts without going to a performance distributor, took me almost a week to find 3/8 size by 24 thread by 3/4 long bolts to use to mate up my flex plate and torque converter lol, hit up all the rural king and tractor supply's around to get the bolts washers and nuts since they usually only had one of each
Sent from my SM-N950U using Tapatalk
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Finally received the 22x9 gm transport steelie wheels that I ordered all the way from Canada this afternoon. It's a small step, but a step non the less for my 64 c10 build. Now I just need to get tires and mount them.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
One more little project finished- the ac control panel has not been illuminated since I got Goldie.
The dash behind, and to some extent the floorboard has, though.:p
So, finally got off my rear , unhooked the ac duct, and reached up, found the wires and bulb, and plugged them in.
Let there be a lighted panel!:D
Speaking of, there is a little bulb in a housing under the dash right in the center of the hump - is there supposed to be an actual floor light courtesy light ?:think:
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I should check the date code on my spare, just for fun since i know its the old style sizing.
It definitely needs more gear.......I guess I could pull the front shaft and drive it in low range lol. Then again that would be to low.
What ratio you have in it now??? I'd think with that torquey big block you shouldn't need to much gear. What size tires???
That and it might not be a good tire. A tire with 20% tread that's about 3 years old is safer than a 12 year old tire with 90% tread.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Congrats. A fix doesn't have to be big and expensive to make a big difference.
And yes, that is a courtesy light.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
3.73 on 36s the cam doesn’t help the low end either.
Ahhh well yeah. You shoulda known better. Cammed it for all low end, but then again, that's how you break parts too. To much take off Powa breaks ****. Set for upper low end or lower mid range woulda been good. Some 4.56's would do some good, maybe even 4.88's if you're not doing alot of freeway driving.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It wasn’t built for street driving.
kobedemello
