Since I think I'm going to have to go with Th400/NP208 Set up I have, I'm thinking of using my 3.73 set up instead of the 4.10 set up. I'll be making trips to my dads in mine and that's 70 miles away with speed limit of 70 all the way so that means I drive 80. It appears I'll only be going with 33's since I don't want a wide tire not to mention cheaper and more likely to get it running sooner that way. Not even sure I'm going to install the lift that I had planend on doing since I have the springs. Might just save the 4.10's and lift springs for a Burb or K5 that I might get someday. :shrug:
For the most part and occasional street.
Fugg it go with 5.38's or 5.13's then. If you're gonna have to regear, get your money's worth. Although, for the cost of regearing you might be able to find a set of CUCV axles with 4.56's ready to bolt in.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Speaking of, there is a little bulb in a housing under the dash right in the center of the hump - is there supposed to be an actual floor light courtesy light ?:think:
Here is the bulb I was talking about - I have had several of these trucks and just don't remember that one...
Underneath the ashtray.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
My 78 has that one.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
My 84 HAD a courtesy light there, but I swapped it out for leds. All of the interioir lighting is led. Long gone are the days of melting the plastic housing and draining the battery so quickly.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You know your life is getting back on track when you actually get the time to wash your truck...
yup I washed BigBlue yesterday. The cabby in my avatar. Man it's a lot of truck to wash btw...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Put a starter in Willy yesterday. I foresee a flex plate in the future........ damn it!!!!!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Im curious to know why you named it willy??
Listen to this song....closely. It’s all in there every nuance tells something about the truck. It’s name is Willy Lee
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
That and it might not be a good tire. A tire with 20% tread that's about 3 years old is safer than a 12 year old tire with 90% tread.
Oh for sure. Only used it a few times when absolutely necessary and stayed at a low speed. If I remember correctly it still had some of the injection nibs on the sidewall.
maybe1day
