CRM
Pasco, Washington
Casey
K2500
350 CI
Changed out the gauge and tail light lense's.
schuy
ct
mike
k30
86 K30 dump..rear wheel cylinders
Just got my 86 k30 dump 6 months ago only drive it a couple times a month. I noticed that the passenger side rear brake line is blocked off, so i decided its time for a new wheel cylinder,shoes etc.
The 14-bolt rear end was easy to pull the shaft out besides of the drum weighing 6 billion pounds all in all an easy job except for running a new brake line where there's only like 2 inches of room between the leaf springs and the wheel cylinder that's ridiculous!!
Anticipating my new engine swap got a donor engine from an 86 K20 Scottsdale pleasantly surprised that they had flat top pistons in it which came as quite a surprise to me considering my dished. All the luck to fellow square body mechanics
bluex
Spartanburg SC
C15
New wheels...
schuy
ct
mike
k30
Vette wheels?
schuy
ct
mike
k30
Nice choice. They compliment it well.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Dropped it off to paint jail.
87scotty
Central il
Andrew
V20
5.7 for now
Swapped out both front calipers on the 87 16$ a piece remans all the parts store carried lifetime replacment so well see if im changin em once or twice a yr and got some misc lights going (the lil ones in rear tails)
SlickGTP
Houston, TX
Finally installed my new to me slider... :cheers:
'bout time too since it's been sitting around for about four years or so. :shrug:
RangRayy
Kansas City, Missouri
ryan
r10
Lucky my '87 calipers were $23 ea. Might be the fact it is equipped with HD brakes. ''Twas an expensive brake overhaul I did two year ago.
87scotty
Central il
Andrew
V20
5.7 for now
You had the 3inch calipers lucky wonder what it takes to switch over to them bolt on or diffrent spindle
twcoley
NC
Terry
C10 Short bed Step side
what was the lug pattern on the Camaro wheels?
RangRayy
ryan
r10
I believe the spindles are different. The rotors are 1.25". Reckon only thing that's the same is the pads. I had a helluva time finding the inner bearing, cross referenced to a 70s vega.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Cantrell299
