Georgeb
Wisconsin
George
K10 Burb Z71
Experimenting? Thats how my fridge in my 1970s truckbed camper runs
Not quite the same your camper fridge works like this.
gmachinz
Harnessworx Inc
Iowa
Jabin
I've recently welded new cab corners on my 86 K10-I spent a lot of time carefully trimming it to look like a factory panel-all aftermarket ones are made to overlap and I wanted to butt-weld it to keep the filler minimal and to maintain straight edges at the rocker and on the rear lower cab edge. Even on a simple weld repair you should take your time and realize even the best replacement panels require modding before, during and sometimes after install.
Well found out that I need to use the correct clutch and pressure plate for my trans. Which means I get to change the flywheel and brand new starter too. So I guess I'll just pull the motor again. Glad I beat myself to death in the evenings this past week just to do it all over again.... :(
That really sux sweaty stinky ass.
CRM
Pasco, Washington
Casey
K2500
350 CI
I've gotten in my door window weatherstripping kit and fuel filler hose today, so tomorrow we'll try to get it all taken care of. Temperature is forecast to be 104* so we'll see.
87ChevyR10
Kansas
NA
NA
NA
I replaced passenger door lock yesterday. Key things to remember: remove cross brace and unbolt the window track brace. Makes getting the clip on much easier!
Sunday, I will be installing a new turn signal switch.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Like it! Links? If anything put an LED aiming down for when you drop a shell or something when loading up for hunting.
I found them on ebay..there are all types of logos and some vendors offer to make custom projections as well. I paid something like $14 for the pair. I am very pleased with them.
bluex
Spartanburg SC
C15
Well all my parts came in yesterday so time to get started on it again today.
At least I got one thing accomplished yesterday. Had to take a road trip to Bristol for it but I think it was worth it. 03 model with 91k miles. Her old one was an 02 with 204k, we got it in 2012 with 98k on it then.
Looks like a clean one @bluex :)
bluex
Spartanburg SC
C15
Ya it seems to be so far. I went to change the cabin filter this morning and apparently that stopped in 02. I have pretty much new filters I was going to use from it but this one doesn't even have to door for them....
From what I remember, the cabin filter was optional. My '99 Z71 had one and so does my '00 Burb, but I don't think my friend's '02 pickup does.
If you are parting out your wrecked Burb, I'd be interested in a couple smaller pieces if you have them available.
87scotty
Central il
Andrew
V20
5.7 for now
Havnt used it yet but that body pannel glue supposed to be fairly easy and alot better in the long run since you dont melt the paint off behind the weld less chance of rusting out again
Washed the 77 and took the boys for rides. Also did some messing with the 87
brentjo
