Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Will be easy to bring the HC down, new plugs, wire, cap, rotor...I hope.
That CO reading is crazy! I knew I ran rich, but wtf?
Mine started to do that the last time I had mine done. Just barely passed. I'm not sure whats up with yours, but I think both of my cats were getting ready to take a ****....still miss TPI though.
Jims86
Patterson,Ca
5.7 TBI
Mine started to do that the last time I had it done. Just barely passed. I'm not sure whats up with yours, but I think both of my cats were getting ready to take a ****....still miss TPI though.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
emissions whats that :p :p :p :p :Big Laugh: :Big Laugh: :Big Laugh:
i finished mocking up my blazer tank in my crew and like the way it turned out. so i braced my cross member and cleaned and painted it and have it ready for final install. and ordered a new dorman tank from rock auto
Rusty1
Washington
Rusty
GMC C10 SWB
Just finished the rear flip and installed the 3" drop spindles and cut a coil off the front springs. Repalced the brake pads ,greased the bairings and installed new seals. Still need to put new shoes on the rear brakes and bleed the system.
Did the rear flip fo 15 bucks. Using summit perches and the old hardware.
Will post pics whan I get a chance.
Ha! Can't do that here... the u-bolts usually only come off with a torch or a cut-off wheel.
A while back, the C20 Burb's battery kept dying after a couple weeks of sitting. I couldn't find anything wrong so I figured it must have been the alarm that I never used. I put a new battery in the remote and used the alarm (keyless entry) and everything has been fine since... until today. The truck had been sitting a couple weeks and the battery was just about dead again. Grrr. Put the charger on it and got in the truck, then noticed there was a faint buzzing noise coming from the CD player. So, long story short, I put another CD player in the Burb today. Never liked the old one anyway.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Found this, which means I'm on the lookout for a new (used) lower control arm for the driver's side before I do my suspension rebuild.
heavyleft
Fayetteville, NC
V10/K5
350ci
Slapped in ORD's heavy duty grease-able shackles today.....pics will be posted in the build thread tomorrow.....cause the front springs was hitting the frame.....thought this was the cause of a new noise....nope. The metal screeching/banshee sounding noise is still there. No pattern to it. Sounds like its coming from the rear. Gonna check out the rear hubs tomorrow seeing how the driver's rear is just starting to leak anyways.
DOH, someone went over a curb or car stop a bit hard !!!
I've often thought of trying to get with a tool mfr (that's manufacturer, not ************) and try to make a reasonably priced sniffer for the home auto mechanic. Kinda like a code reader tool. Except that it has a tailpipe sniffer instead of reading codes, and shows the NOX, O2, HC and CO readings to where a guy can work on his own vehicle and get within his limits before he goes down to test.
Rusty1
Washington
Rusty
GMC C10 SWB
completed the drop
Before
After
zapattack
