Chaz; example:
With the addition of greasable's in the rear all my suspension points will be able to be lubed.
Since Ive tore apart my 33yo 56'ers Ive also noticed how wore out the spring pad inserts can get (usually on the ends of the springs to help the spring below it slide).
Ill be replacing those as well....might be something else you want to look into.
Google: leaf spring pad inserts.
Good read: http://www.bsfab.net/?p=65
That link is some damn good info. And ran the teflon the whole length instead of just end pads huh? To bad we have to delete that link though cuz the guy included his blood from where he cut himself trimming the teflon. :sad72:
SlickGTP
Houston, TX
What blood? I just see some ketchup that dripped off the burger he had to be eating while fabricating... ;)
Yeah, Yeah, un huh, that's what it was. My bad. Didn't realize he made a trip thru the drive thru on his way back from getting parts.
8T6K5
AZ
L98 350 TPI
Just aquired some more parts for my shackle-flip w/56'ers project...
Thanks 1986K30 !
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Finally got around to replacing my sticking caliper and ruined rotor. Still low on brake pressure though. Going for the MC this weekend.
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
Greasable bushings,,,,,sweet!!!!!!!!!
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i finally got my 6'' rear springs cleaned and painted and loosely put them in my crew cab.
i ordered new teflon pads and got the wrong ones now i am waiting for the correct ones to get here. thats why i loosely put the springs in my truck i still need to take them back apart for the teflon pads
.http://www.gmsquarebody.com/forum/showthread.php?t=2329
8T6K5
AZ
L98 350 TPI
i ordered new teflon pads and got the wrong ones now i am waiting for the correct ones to get here. thats why i loosely put the springs in my truck i still need to take them back apart for the teflon pads.[/url]
Where did you get the pads from? They are hard to find and $$. Local dealer wants $16ea !! Summit has them for $5.70, but still $$....
Sent from my iPad using Tapatalk
I never heard of Teflon pads? They go on the back of the brake pads?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Nah, they go between the leaf springs for noise reduction, and so the springs can slide on each other easier. Factory spring packs have them (or something similar, in any case).
They fit into a little hole at the end of the leaf springs:
8T6K5
AZ
L98 350 TPI
That little guy right there ^^^ is nearly $6 at Summit ($16 at a local dealer)...
...and I need 12.
chevydude
arizona
hunt
k20
just picked up the bracket from my scho0l so I can run u bolts upside down in the rear
8T6K5
AZ
L98 350 TPI
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i got the pads from jackit.com they are a 4x4 shop in salt lake city 2 bucks a peice check them out they have a couple styles in stock. they are good to deal with i buy alot from them.
i have rough country rear springs they use a round pad with a single stud. they sent me rectangle pads with dual studs.
they did not want to pay return shipping on them so i got to keep them and they are sending me the rough country ones for no charge.
and the rectangle dual stud ones are correct for my skyjacker front springs so it works for me.
8T6K5
AZ
L98 350 TPI
thom9719
