kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
call them i normally call them to talk to a human thier toll free number is on the site.
chevydude
arizona
hunt
k20
Why would you want to do that?
So the round part of the U bolt are on the bottom of the axle I makes it for better ground clearance.
8T6K5
AZ
L98 350 TPI
So the round part of the U bolt are on the bottom of the axle...
That is right side up, hence the name "U"bolt.....
Upside down would have you're bolts chewing rocks.....
chevydude
arizona
hunt
k20
Alot of stock you bolts go face down where the bolts are on the leaf spring and the bolts on the bottom. The ones I picked up from school make it so the bolts are on the top.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I've never seen a Square bend U-bolt on a Squarebody...
EDIT: Guess 1-tons have them that way.
chevydude
arizona
hunt
k20
There not quate square they are round but some of them run with the bolt part of the u bolt faceing the ground
8T6K5
AZ
L98 350 TPI
That they may be, and that is "upside down"...
It could be done for several reasons, but technically they are still "upside down"...
So in essence, you turned yours right side up....
http://www.offroaddesign.com/catalog/uboltreversal.htm
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
starting the blazer tank install
i have a few more pics and i will have more info on it as i get it done posted in my build thread a link is my signature at the bottom of my posts.
Yup, on the 1-tons.
Yes, the ends are square because they go over the springs, the springs aren't round. Still called u-bolts though.
They did it for frame clearance. The 1-tons have the springs mounted closer to the frame, if the nuts are on top they can run into the bumpstop bracket. Like this:
ChevyBoy84
Cedar Rapids, Iowa
v10 silverado
removed factory oil pressure, volts, and temp gauge and installed mechanical gauges, i wish i could have gotten a picture that was a good one at night but my phone didn't want to take one that was even close to good but it is what it is lol
Looks whole lot like Mr Clean's Dash.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I was real close to doing somehting similar untill i started finding where the PO had just unhooked the gauges from the engine and left the wires hanging because the sending units went bad and i guess he didnt like seeing the gauges reading wrong he was a real DUMBASS
I've thought about doing what Clean did, then thought about selling these 2 I have and haven't done anything with them yet. They were bought for a project but plans changed. Still used the Tach and the Trio but now these lay around.
attachment.php
attachment.php
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
got my modified vortec harness from luke (oneluckypops) today
it looks awsome he does great work for a really fair price. if you need a harness modified hit him up.
Rusty1
Washington
Rusty
GMC C10 SWB
My wife sewed up a new seat cover and we installed that after I patched the giant worn hole in the foam.
Installed new carpet sinse it had the old stuff removed before I bought the truck.
Reinstalled the freshly covered seat.
Rebuilt the steering column. All the tilt bolts were loose or completly out and the shifter drum was broken and missing a big piece along with a worn out ignition switch.
Bought another tilt column that came with the keys that was also falling apart for $20.00 and used the good parts from it to rebuild mine. The ignition switch was brand new. Rusty is coming along.
thefoxtango
