PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Was moving my busted axle around and got really pissed when the c-clip kept popping out and having to reset it. So if you don't have a center pin and just need to move your truck or axle around your yard, here's a simple little hack.
I measured to find the closest bolt, was about 3/4 of an inch, then I took the threaded end to the bench grinder until it fit between the axle shafts, then simply install between the shafts and "loosen" the nut, which will in turn keep the c-clips locked in the spider gears.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
The smart @$$ answer is that they come with a new inner fender. I'm not aware of them being available as a patch piece. I figured I would be cutting and fabbing replacements by hand if I got to that point.
Do they? I'm not regularly searching for inner fender. The last time I saw some they seemed to be one piece and not have those plates or whatever they're called.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
My '85 and '86 both have them and they're part of the inner fender. Dunno what goes on with other people's trucks.
dusterdude
US
mark
gmc c15
Installed a t fitting trailer plug this morning
Sent from my LM-X420 using Tapatalk
jjester6000
Illinois
Jack
C1500
'Ol Yeller has been looking pretty crappy lately, so I decided I want it all one color again.
Its all one color again.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
good match actually. hell of a change my friend, hope you like it
jjester6000
Illinois
Jack
C1500
Yea, it's a great match.
So for reference, GM 511 Ochre is a really good match to Ace Hardware Catapillar Yellow Enamel Tractor Paint.
jjester6000
Illinois
Jack
C1500
Last time I painted the truck, I had at least 5 people see it in my driveway and ask if it was for sale, then they got close and saw how much of a POS it was.
I expect that will be happening again.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
haha i love it
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Changed the PCV valve - hardest part was that dam spring clip and the fact that I did it while hot.
But, what the hey - done.
Also got 2 gallons of 15W40 Supertech for $ 20.89 for an upcoming oil change.
79K15 HIghSierra
South Carolina
Reuben
K1500
Well it’s been a while I’ve been busy as hell; but managed to get some done to the ole girl. New shoes,(33/12.5/15) set me back a good bit but it needed them bad. Finally got it painted! Satin olive and my wife suggests black trim.
chevelless07
