Camar068
Kentucky
10 yrs Air Force
Hooked up the scanner and noticed that the O2 sensors voltage read differently. This could be due to an issue with either bank. I would expect (not knowing any better) that the voltages for each O2 sensor would be relatively close to each other. These are the sensors that came off the donor vehicle with the engine.
I've felt a drop in performance over the past month, so i went ahead and ordered some replacement NTK O2 sensors to install. I'll update with a pic after the install.
I did notice a 2005 LM7 with 140k miles (no harness or front accessories) on FB for $400. I plan to go ahead and get it and rebuild pending price of parts.
[Update/thought] It may be because I think I've got a small exhaust leak under the drivers side cab area. May have some play with the readings.
full
Bronze Knight
USA VA
Robert
Got a few things done today. Not all of them good.
I tried and failed to remove the front pinion yoke nut, wanted to replace the oil seal behind it because it’s leaking but all I managed to do was round off the nut.
After that fail I decided to put it all back together and let that sit. Probably going to have to take it somewhere, that one may be beyond me. Still had some time so I got to work on cleaning the floor in the rear in prep fo POUR 15
While I was there I got a better look at my rust situation. Need to source some patch panels at some point.
And finally I figured out why I had no speedometer today. RIP
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Yanked the big block trans and efi from my k5 yesterday, todays task is axles and tires....
Big block c10.....here we come
I like it, but at the same time, I don't like it.
Lol
Vbb199
Salisbury NC
Vince
Lol
Im not a fan... but that (was) TOO MUCH money under the hood just sitting.. about 15k in engine, trans, and EFI.
Time to move onto a hotrod i can terrorize everyone with.
The88
Mhmm
South Louisiana
ThatGuy
K5ton no more?
SirRobyn0
Alternator went out today on the way into the shop. Was replaced by the former owner before I got it so it was about a 3 year old NAPA alternator. But what to replace it with. No I've not been happy with Napa house brand parts in many years now. No not a duralast, no not a masterpro.... What's left that I could get same day... Yes of course an A/C Delco remanufactured alternator! The only way to go!
see
SirRobyn0
@SirRobyn0
Sound starter and alternator in Tacoma does good work, for future reference.
Thanks for the tip, I will get in touch with them for future work. We do quite a bit of older rigs at the shop and could really use place like that from time to time. There use to be a shop in Woodinville called, Woodinville Auto electric. One of his last Alternators is in my 77 Cadillac, he had a great operation back in the day.
Loco Hills
K-30
Man,that’s the pits.Use a dremel with a cut off wheel and cut the nut.One side should be sufficient to relieve the torque.It will be a bit tedious,but take your time so you you don’t cut the shaft.
Wear eye protection
HOTFOOT
northwest ct
michael
gmc k3500 srw
Buy a chrome 6 point socket the impact socket is to thick to fit down into the yoke I had to do that with my k3500 or borrow a socket preferably a snap on or Mac with flank drive that’s what snap on calls it
Vbb199
Salisbury NC
Vince
Got the k5 completely torn down yesterday. Its just a body and frame, tires, axles, wheels, 5 ton shafts, and all thr other 5 ton **** is all headed out tomorrow morning.... in the mean time, the money i dont even have is burning a hole in my pocket, im going to look at a 79 c10 shortbed, i6 with 3 speed today after work... all original. Red, 2800$ runs and drives now.
If i get it, i'll be sure to make a build thread, namely featuring how i yank that i6 and toss it in the dirt and replace it for a motor damn near twice its displacement
thatgermanguy
