gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Cleaned the windshield and drove it to the gas station to fill up.
Also lubed the door hinges because Brown has become a place to play with for my kid and there has been a lot of door opening and closing. There are no interior lights so no battery usage, just latch and hinge play. Reminds me when I used to play in my dad's old truck in the driveway. Good times.:happy160:
80BrownK10
Greenwood, SC
Nate
Washed it, sprayed it with quick detailer, and took it out for a nice long drive.....
Ni e truck
RedBeard_83
Florida
Cory
Custom deluxe
Sbc 350
I think that's how they are from the factory. Rain x can work wonders
Yea I replaced everything. Originally only had low and they would not park and didn't have a washer fluid reservoir so I bought it all. Replaced unit inside steering column and new selector switch , motor and reservoir. So back to working like new . is there a conversion for the j hook style wiper arm for the squarebody ? Not a fan of this pin style I have . seems very loose wobbly .
HOTFOOT
northwest ct
michael
gmc k3500 srw
Dropped it off at the tuner’s Wednesday after the exhaust shop. We figured out it wouldn’t run cuz the fuel pump had died. That’s #2. First one died 30sec after firing it the first time in October, it was a parts store brand. This second one was a Delphi.
So got my dad to help me drop the tank and throw in a genuine GM AC Delco Thursday night. Got it running, let it run for 3-4min and shut it off. Tuner said he work on it Friday. He calls me Friday, says I need to bring him an injector, #2 is dead. No big deal. Bring that, we get it changed, go to fire it up. Nothing. Fuel pump is dead again [emoji2959][emoji2959][emoji2959]
His shop is in a real small industrial park and he doesn’t have room for me to leave it three. So I’ve gotta grab the trailer from work again and I’m gonna bring the truck to work to drop the tank again. Plus we’ve got a huge lot the tuner can drive around in once I figure out this issue. I’m thinking either the sender is slightly too deep in the tank and the pump is creating suction or somehow I’ve gotten 3 bad pumps. The second pump ran flawlessly for about 6 months as needed, so the wiring has to be right.
Sent from my iPhone using Tapatalk Pro
some good reading !!
https://www.lsxmag.com/news/real-street-performance-puts-22-in-tank-fuel-pumps-to-the-test/
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Finished cleaning up the back brake on pass side sprayed a light coat of paint on and put new cylinder in.
Sprayed some caliper paint on the other parts and semi gloss on pb piece and springs.
I know you can't see them but, I'm hoping it cuts down on them rusting in the future. I'm still waiting on the rest of the kit so might as well do something. Lol
hoagster
California
K10, 1500
5.3l
Repaired my old 40lb blaster, tested it out on one side of my passenger side door. Finished the down to the metal with my favorite tool. Cleaned it then rattle caned it. Still need to fix all the mirror mounting spots over the years. And blast the other side.
Octane
Atlanta
Eddie
Dont forget a small dab of grease wherever your brake hardware contacts the backplate.Makes for some quieter smooth brakes.
Loco Hills
K-30
Got less than planned done, but still a decent amount. Replaced the valve cover gaskets and adjusted the valves to zero lash. Removed the last ac bracket off the engine, until I put it all back on later this year. Changed belts, tightened down the power steering pump and the loose lines, and added a new air cleaner. Sparkplug wires tomorrow. Next week plan to do the oil pan or exhaust.
Nice headers too
Loco Hills
K-30
Got my wipers working as they should . I now have two speeds and they park like they should. High spd isnt much faster than low spd but its a little faster and should do fine with the help of rain-x
I did this same thing earlier this year.Gotta love working on that!Seemed like I’d never get mine right,but finally did.Also,getting washer fluid spouts to shoot straight is fun to.
Camar068
Kentucky
10 yrs Air Force
changed the oil. Also started wiring in a new plug for electric windows.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
I used this one. Some have criticized that they are for Ferd, but I use whatever works if it is better than the original. There are probably others that are for GM, but this is the first one I found that works for me.
https://www.oreillyauto.com/detail/...3/dorman-help-windshield-wiper-arm/mtm0/42631
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Well here's a question to all:
Would you rather buy a PRESTINE Square Body, already done, practically brand new.
OR
Buy a total POS Square Body and go through the process of restoration and making it your own.
......and why?
EDIT: okay there's no such thing as a "POS Square Body", we'll just go with "rough around the edges; needs a TON of work"
Option C:
A truck thats been in the family almost its entire life, that got abandoned for years, then someone breathed a whole new life into it. A year ago with new drivetrain and suspension parts
thatgermanguy
