Picked up some goodies today from a friend of mine while I was at his farm. A few hubcaps to split between a buddy and myself for our offices, a blank tailgate band in decent shape and an extra rally to use for a spare. It just so happens to have a 275/60/15 so I can see what that size looks like on the truck. Then stopped at Tractor Supply to grab a chest box for extra storage. This regular cab life is really pissing me off [emoji23]
Sent from my iPhone using Tapatalk Pro
Poppy 87
Bloomingdale GA
R10 Silverado
I'm interested to see how that tire fits. Be sure to snap a picture. How did you install the tool box? Did you use the bed mounting bolts?
Sent from my XT1254 using Tapatalk
legopnuematic
Licensed Junk Dealer
MO
Spencer
Sold my 85s cab and front clip on Saturday, now to make the frame into a trailer frame. Anyone dying to have a 2.73 open 10 bolt?
Sent from my Moto Z (2) using Tapatalk
I think that tire will fit just right in the rear. Gonna try to get it to hold air and test fit later this week. It’s too dry rotted to try to run tho, I’ll just back it out the driveway enough to flex it on the curb lol
The box is just sitting there for now but yes, I plan to use the bed mounting bolts. One of them is spun in the bed floor, so that’ll be fun to get out. I’ll probably get some extra thick washers and cut a square in the for the lag bolts to sit in.
legopnuematic
MO
Spencer
Weld a nut ontop of the carriage bolt then you have something to get a wrench on, or use a nut splitter on the bottom, or plasma cutter or torch to cut the nut
MisterB
Northwest
AJ
GMC K2500 4X4
Just bought a 91 suburban one week ago and have done several things to it!
She got new exhaust, cleaned the throttle body, set timing, cleaned the engine bay, and vacuumed out the inside. Also took off the grandpa looking steps and bug guard.
Sent from my SM-G975U1 using Tapatalk
That thing would look cool flat black rattle canned, with a beefy bumper/grille guard
Sent from my SM-N975U1 using Tapatalk
I’m gonna try welding a nut on the carriage bolt. The bed’s nice, hoping to avoid the plasma cutter
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Tonight, and the past few days I've been going thru a big cluster F of wires, partially my own fault, partially this big discombobulated setup I have I call the k5ton.
I have a 87 suburban cab harness, 89 instrument cluster, and a 91 k5 engine bay harness.
I need the cable speedo for my th400 (it was in there when I got the truck) and I'm using holley efi to feed my 502 ci big block, so ECM and so forth in the k5 does nothing.
When I started back on this project, I tackled wiring first, threw my marine battery in, wired up the efi, Alt, starter, body, frame, and engine ground.
When I turned the key for the first time, the efi turned on, starter engages and rolls the motor over, I have headlights, taillights, turn signals, engine temp was pegged all the way over, oil pressure jumped to zero, voltage went to 11v, I had no fuel pump, no fuel gauge.
Tonight, I got the fuel pump working off the fuel pump relay under the hood. I used the EFI's fuel pump 12v trigger wire and tied it into the fuel pump relay's green/white wire. It now triggers the fuel pump when I cycle the key.
Next up was determining my fuel gauge situation, I checked resistance, no issues on the sweep of the float... So I couldn't figure out the issue... I started looking, and I found my issue... I guess somewhere between the crossover from a 91 engine bay harness and 87 cab harness, some of the wires flip flop around, and the cluster's main bulkhead has a different pinout as well...
Remembering that I had the k5's old cab harness, I dug it up, checked the pinout, sure enough it was different!
So for the last what seemed like 1,000,000 hours, I went thru each individual wire that goes to the bulkhead, placing it where it should be to make the gauge work correctly.
All that's left is the oil pressure signal wire.... I need to go under the hood, and get the oil pressure sensor plug, firstly extend it to over by the power steering Pump because thats where you screw in the sensor on the gen 6 bbc as I was told, and then, trace down the signal wire and tie it into the instrument panel.....
So, fingers crossed, tomorrow when I button all the electrical back up, I'll have engine temp working right, fuel gauge, and all that other stuff!!
Good times!!!!
85squaredC10
Wisconsin
Jason
Good times!!!!
Nice work!! I remember when I blew apart my harness for my 85 to 93 tbi swap. What a mistake!! I took 2 seasons to learn ALL the wiring diagrams and pinouts. It was a huge job, but I got it all done and it runs fantastic!! While I didnt want to take the time, nor did I want to learn wiring, I succeeded in doing both. Feels pretty great when it fires up and you can drive it without issue. Keep up the grind brother....its definitely worth it in the end. Cant wait to hear it start up...post it up when it fires!
Sent from my SM-G965U1 using Tapatalk
Vbb199
Salisbury NC
Vince
I'm very close at this point to squaring away all the electrical, I'm rushing to get all that done and just literally be standing and waiting on the 60 psi fuel pump to come in, and once it's arrived, I can put it in the sending unit, hook up the lines, and fire it up.
Man did I ever consume a huge amount of knowledge tonight in wiring!
I charged my battery today. I've been gone for 2 weeks and when I got back to the shop, I found my battery was completely dead. Then I noticed my old Grant horn cap had come loose and made contact. Apparently my horn was blowing until the battery died. I bet the neighbors across the road loved that :rofl:
And my low note horn no longer works now.
Vbb199
Salisbury NC
Vince
LMAO!
80BrownK10
Greenwood, SC
Nate
hit my front bumper with rust reformer.. had a tiny bit left over from another thing. ran out, but got most way. i think it will hit with a matte black paint, too
Also, painted my trailers tailgate john deere yellow. because why not :)
and between the oil change for this truck since ive got it running beautifully and paint the front bumper, I used about 6 tubes of grease on this truck, my f150, and my trailer.
6 tubes.
5 of them on the square.
Dang what are you putting all that grease on/in. Are you just rubbing down the frame in grease?
Catbox
Peter
C20 Silverado Camper Special
You and I are gonna match buddy....
I bought a Mack truck bulldog several years ago for my k5, it's lost somewhere in the thread :cool:
Since you got a hold of me and I took the photos of the remounted hood ornament, I figured I would post them here for others to see as well.
One before.
The rest are afters...
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
One before.
It's hard to tell from a photo, but I think you've got a pup-dog there. Which is okay, the ones for the truck hoods are kind of big for a pickup truck. It still looks good.
jlyon1006
