C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Weighed it today. 4245# with me and both tanks full. ~3865# dry weight
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
The later ones called for ATF. I'm not sure if running ATF in an older one would cause problems though.
The seals did not like it - I tried it when I 1st got the truck as I did not have a owner's manual, but have a 82 FSM which called for ATF.
Unknowingly I bought synthetic ATF which may have been what it did not like.
That said, any ideas if the overfull condition would cause it to make funny sounds only at a certain rpm and above?
I will find out Saturday morning, but if anyone knows the answer before then, cool.
Poppy 87
Bloomingdale GA
R10 Silverado
I don't think an overfill condition in a gear driven t-case would cause noise, probably only leaks. It's "splash" lubricated like the differential, no pump to cavitate or surge.
Sent from my XT1254 using Tapatalk
80BrownK10
Greenwood, SC
Nate
I may be wrong, but I don't think the np205 takes atf, but gear oil. In which case, the mixing of the two may be problematic.
Your correct. The 205 just takes gear oil. That said I have heard some run ATF. But also it's just gears and bearings and I don't think his normal running so far would have hurt it. No oil would be worse that half and half over full
80BrownK10
Greenwood, SC
Nate
I'll be pulling them off of the Suburban at some point. One has a little rust on it though.
Are y'all talking about the bumperettes? Those things on the front bumper that protect it from an forward impact?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Spent 8 hours saturday doin a rear swap and conversion.
Hey @eskimomann209 this was the last time. This is when i killed the factory 12 bolt and built the 10 that i just cooked.
Yeah. They have gained the nickname around here as "bumper thingies".
eskimomann209
Modesto
Marcus
Ohhhh got it. That’s rough.. just a gear swap or just a posi swap?
I know people say that it’s ok to swap the ring onto the new carrier but sometimes it’s better to take that little extra time ( and money ) to knock it all out. Usually if I plan on keeping something old, I spend a lot of time inspecting. And if I feel slightly nervous I swap it out.
Cheaper to spend money on a new crush sleeve to inspect the pinion bearings VS a whole rebuild. But I’m a wiggly one. I’m no rear end expert but I have rebuilt a lot of gear boxes in industrial settings.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Old rear was a 3.08 new one was a 3.42. I left the 3.42 pinion alone and just put the ring on the new posi and put it all in
TubeTruck
East TN
Denis
Suburban K10
LQ9
Get a 12 bolt out of a 4x4 with 6 lugs and make a Lincoln locker. You'll love it :burnout:
TubeTruck
East TN
Denis
Suburban K10
LQ9
For a daily driver!!??:gathering:
It all depends on someone's tolerance. Personally, I love having locked axles. Some people hate it. Just like some people like manual hubs and some like drive slugs or auto hubs.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I like this eaton clutch posi i have but i dont think id hate constant 2 wheels pushin
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Sadly, you were correct- the overfull was not the source of the noise.
Would have been too easy...
:p
Sharon
