silverscottsk10
trafalgar indiana
mike
Back to the parts store, ordered the parts friday. Picked them up today in a rush to beat the rain and only gave my one ball joint, guess I'll order those online
Sent from my SM-N950U using Tapatalk
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Man, parts houses aren't what they used to be, I miss the days where there was that old guy behind the counter with that book that was a foot thick...... now its a joke. Took me 4 times to get the right carrier bearing for my drive shaft on my truck.
silverscottsk10
trafalgar indiana
mike
The only one I haven't had an issue with anymore is napa, everything else has been useless or just wastes my only full day off work running back and forth 5 times, I'm gonna start taking chances online, instead of having the truck tore apart thinking I got everything lol
silverscottsk10
trafalgar indiana
mike
Getting a little work done on the 350 for the 85, have to buy an oil pan as the one that came off is pretty well destroyed from over torque of the bolts and the one I bought was left hand dipstick and the block is a right hand only
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
In my efforts to correct my pinion angle, I have discovered that the wreck I was in last year did in fact bend my rear axle. Explains a lot of issues that I've been battling. Off to craigslist I go... dammit. :shitsweak: stupid 10 bolts.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Good luck. I find it easier to find 10 bolts over 12. Im still lookin for a 12 bolt posi for my square
Kyle Childress
Brownsville KY
Kyle
K20 silverado
BOOM!!!! Found the perfect roll bar for my truck!!!
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Took my wheel off and re-oriented it and drilled a new hole so i could access the horn button. Hit the wire to the center and the horn works. Hopefully soon i can get the horn button setup and put the center on it.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
What tach is That? How do like it? Been looking at some for mine.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Its an OLD sunpro. It came out of my 90 k1500. It was in it when i bought it in like 2005.... its a super tach 2. It works good and i put an LED bulb in it so its bright. I like that its compact and fits nicely between the gauges in my view.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
This also raises a question... the redline has always been set at 4k on both trucks it was on. Both stock sbc 350s, what is the right redline for a stock 350? Anybody know?
legopnuematic
Licensed Junk Dealer
MO
Spencer
I'd say about 4500 rpm is where most made peak power. No reason to go past peak power, but probably 5500 as a 'safe' redline, if valve float doesn't occur first.
Sent from my Moto Z (2) using Tapatalk
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
How would i know if theyre floatin lol
legopnuematic
MO
Spencer
When the engine decides it doesn't want to keep revving, runs out of wind. Say you hold it in 1st and mat it, when it gets to 5500 or whatever it will not continue to gain revs.
73c20jim
Tombstone, AZ
What have I done? What has it done! It pissed me off today so I kicked it in the balls and went inside and watched TV,
Burban90
