smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Replaced the cheesy oem rubber sway bar bushings with polyurethane. Wow...what a ride difference.
I also ditched the plastic coolant recovery tank with a polished stainless steel unit that I picked up at the last GoodGuys car show in Phoenix. It takes up little space, and it looks so much cleaner in the engine compartment.
smoothandlow84
Steve
This is what my wife got me for my retirement gift. Great Gal
...now that's some nice jewelry there! Very nice!
silverscottsk10
trafalgar indiana
mike
Added a stripe
Haven't yet, I need to put a new ignition tumbler in the C20. First the helper ring broke off, now the key broke off in the ignition.
Don5
West Virginia
Don
k15
^Now that sucks!
I filled the front end with synthetic fluid and greased the front end.:)
^Now that sucks!
It was bound to happen. The ignition gets tough just at the START position since I've owned the truck. I'm surprised it last this long.
MadOgre
NA
NA
NA
NA
NA
Push Button
MadOgre
NA
NA
NA
NA
NA
All the really expensive vehicles have it!
farmer jon
Nebraska
Jon
k20 Bonanza
Hooked a chain to it and dragged it from one side of the yard to the other.
Green79Scottsdale
G.R. - MI
Bob
Scraping gaskets off the heads so new intake gaskets can go on. Intake, valve covers and air cleaner painted. Now I just need to get everything back together and hope it runs.
mbl530
new york
michael
350 ci 375 hp
what have yo done to your sqare lately
Where have you been shorthand? I finally got my new compressor hooked up. I shouldn't have any air issues now. I've been reading a lot on should filler go over or under epoxy primer, and wow, there are guys who insist sand with 36 grit and do filler work. Then there are just as many who say apply epoxy primer 1st scuff with 180 grit, then do bodywork with filler, then apply another coat of epoxy to the repaired area afterwords. What is your thought on this topic?
smoothandlow84
Steve
Been under the hood of the truck and replacing front end bushings....
I always sand down to bare sheet metal before applying body filler. The bond MUST be to metal, or eventually it will crack, or even chip off.
MadOgre
NA
NA
NA
NA
NA
POR15 it and then apply filler :) I freakin hate bondo! The POR15 will protect the metal from any moisture. I have never seen anything last more than 10 years before allowing the metal to rust.
Georgeb
Wisconsin
George
K10 Burb Z71
Agreed! You must stop or remove the rust. Also any pin holes through the sheet metal will just allow moisture in behind the repair and cause failure. Bondo for dents on good steel is OK given you pull as much of the dent as you can first and your filler thickness is minimal. Rust or rot must be blasted or cut off and replaced.
jlyon1006
