jt1200r
- May 24, 2011
- Huntingtown,MD
- Jeff
- r10
- 4.3/th400/3.08
fixed a rusted shackle.
Made my wife a little mad, it was too cold to work outside, so I overhauled my 670 carb in the bedroom. I was told there were fumes.
Replaced the lower hinge pin and bushings on the driver's side door. No more vertical slop.![]()
I took the lazy way out. I did not want disconnect wires from door locks and window, so i ran a ratcheting strap over one of the cross beams in my garage, looped it around the top of the door and pulled it just enough that the door would not drop. Unbolted the hinges from the door, cut the old pin as it would not push back thru the hinge, reinstalled new bushings and pin and bolted hinges back to door.What a coincidence. I just replaced the upper hinge pin and bushings on the driver's side door. No more vertical slop for my truck as well.
Come to think of it, the lazy way might have been more work than the other alternative.![]()
Just got my new motor back from the machine shop and went by and picked my tranny up and got home bolted it together and had it on the hoist lifting it up to get it over the core support and Bam. one of the bolts broke that held the chain to the back of the head and the motor and tranny hit the ground busting the rear of the tranny, oil pan and the fuel pump. What a DAY
