v2500burb
Charlottesville Virginia
Jay
v2500
350ci
E-brake has never worked
When the frame and under carriage were coated they sprayed it
350runner
tx
Ceasar
Gathering parts for the cs144 to show parts that I feel should be replaced b4 install... made a new square body parts contact in Plano, tx. Got a dam near new HD rotor, drum, and drip rails for the square for $30 :) just got to find time to put em on now too much work...
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Had a tire blow out. Ripped off my exhaust smashed up the fender pretty good and wacked the tailgate. Fml 35km2 did some damage
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Anyone know where to get Original Chevy/GM key blanks?
Dealer? I think i paid 3 each. They were even able to look up the proper keys i was supposed to have so now i have good gm keys rather than duplicates of duplicates
Sent from my Nexus 7 using Tapatalk
flyboy1100
UsA
me
k1500
So they cut them to the original code for your truck
Yes. We compared them to the duplicates, they had a lot more detail, so it was a little questionable as to if they would work, but they worked waaaaayyyy better than my duplicates or who knows how many duplicates
But if your locks and ignition are still original you should be OK, i gambled on mine and it paid out
Sent from my SCH-I605 using Tapatalk
MadOgre
NA
NA
NA
NA
NA
I tried that but it was soon apparent that some one had replaced the tumbler with something from another vehicle all together. But I still got keys cut that work which none of the hardware stores could do.
GM sent their mobile guy to fix me up. same guy who fixed all their cobolts lol
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Exhaust time!
Finally installed a new exhaust. Went from some unknown-brand mufflers turned-down in front of the rear axle to a set of Flowmaster Super 44s run through mandrel-bent flowmaster tail pipes out the back. I'm loving the sound/look of it, plus it took about an hour to install. Not too bad! I like the sound, at there is almost no drone in the cab anymore - it was REALLY bad before. I'll post pics once I get the tips and H-pipe installed. For now here are some before/during (oh yes)/after videos. I hope they work!
Before with unknown-brand mufflers turned down:
Before Video
With no mufflers - I just cut them off and let the pipes hang (wife was with me - you think she liked it?):
454 - Allowed to BREATH
And finally with the Super 44s and tailpipes:
Super 44s
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Removed 4 trash bags worth of floor insulation, dirt, broken glass, straw, trash, random debris,... out of the bed and floorboard of my new '84. Getting it all cleaned up so I can decide where to start fixing it.
flyboy1100
UsA
me
k1500
found my dragging front right wheel issue...argh!!
finished drivers door weather stripping
swapped fuel tank switch (everything works now, just need to get some gas to test out drivers side tank!) i know it will die if i swap to it because it is currently empty
need to finish passenger door, it just doesn't want to line up because the PO ****** up the regulator mounting.
can almost get it out of my garage!
v2500burb
Jay
v2500
350ci
Does anyone know where you can get kick panel enclosures for A reasonable price
Everything I have seen is $140 - $190
Dadof2
Central Texas
Craig
R1500 Chevy Sub, C20
350 in both trucks
Removed dash looking for wiring issues:
lsswapped
