Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Seafoamed the intake, took the sticker trim off of the side, got the doors on, took the whips off, and almost lost a finger
Sent from my XT901 using Tapatalk
cbrodine
NW Ohio
Collin
C25
New wheels and tires...Black Rock Type 8 997's 17"x8" with 265/60 17's
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Seafoam is definitely fouling my plugs.
I'll replace when the tank is empty
I also need to find the vacuum leaks
Hopefully it's at least cleaning the fuel system in the process. If it's that bad, maybe you should dilute the seafoam. Add 5 gallons or so of gas to stop the plug fouling. Then you have longer and more miles of fuel system cleaning.
v2500burb
Jay
v2500
350ci
It's only until the motor warms up
If I stomp the pedal when it's cold it will miss
datto62073
Monroe
Mark
changed the gear lube in my front diff, transfer case and after lunch i am doing the trans. also cleaned up the vents for teh front and the transfer case. cant find the one for the trans though as of now. still looking though.
silverscottsk10
trafalgar indiana
mike
Bed lined the bottom of my cab and made me a new switch panel out of an ashtray from my parts truck
Those both turned out good. Somewhere around here, this is a thread about what to use the ash tray for. We need to add that one to it.
heffalump
Lafayette ga.
jeremy
2500 suburban
Got rid of a squarebody last night... Down to just one now.. :bawl:
Boone
Al.
About this time last week. While workin on gettin the pushbar to mount.
Me and some friends at work made a stainless steel bowtie grill. One of a
kind as far as I know. Not installed yet but have some off days comin up.
Here it is with white plastic protective tape still on it.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
manual window regulator on drivers door
v2500burb
Jay
v2500
350ci
Changed 24yr old spark plugs
Was running short on time...
Wires
Cap
Rotor are next
She goes into the shop Monday for all new a/c components
transportjockey
Albuquerque, NM
Nathan
454 V8
Got a hold of done wiring diagrams. Got the gauges off. Probably gonna strip out everytHing that's not factory and go from there.
And put in eight new spark plugs
Sent from my SPH-L720T using Tapatalk
F1r3truck
