waterpirate
delaware
v10
5.7 tbi
So I finally got my lock out of my glove box.... with a 6 inch cut off wheel lol! Ready to install new lock and glove box on SAt.
Auburn, Washington
I wish I'd have watched this before I did it....
I'm gonna watch it tonight! Quick scan thru it, he used 8 clips along the back of the cab. One of the parts places, LMC I think, said 5 required. How many did you use?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Today, so far, I reversed the side grill trim to put them back on the right sides. I also wrapped the wires going to the passenger side of the engine (choke, alternator, and starter) in heat resistant loom and tape. The previous loom was plastic and basically fell apart every time it was touched.
Ah... so much better.
Snoots
Roger
Jimmy Sierra
350 w/203
I'm having big issues my my hydraulic clutch on my 86 right now too.
Pedal goes all the way to the floor, and it still wont shift. Low grinds, and 2 3 4 and R just wont go.
Master, slave or both need to be rebuilt. Flush the entire system too.
CRM
Pasco, Washington
Casey
K2500
350 CI
Afternoon session:
I was pretty excited this afternoon as my rear bumper showed up. Something didn't look right about the box though. Upon inspection I found the bumper bowed and a couple of dings in the top. I hate the thought of having to take this back to UPS and waiting on another one.
Decided to continue on so I pulled the rear drive shaft to replace the leaking TC output seal and install new u joints. Seal was a piece of cake. The u joints on the other hand weren't. After hearing the new one pop I measured the new ones against the old ones. New ones are 1/8" longer thus explaining why the end punched out.
CRM
Pasco, Washington
Casey
K2500
350 CI
I recognize that interior from Youtube.
CRM
Pasco, Washington
Casey
K2500
350 CI
I decided to take the bowed bumper and set it up behind the truck to see what it would look like. It was barely noticeable, so I went ahead and installed it. Also put the new Husky floor mats in the cab to protect the new flooring I put in recently. Next up is the exhaust system. I received the Y-pipe today so out comes the crappy dual exhaust someone hacked in previously.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Where did you get the huskies?! Are they universal or square specific?
Auburn, Washington
Trying to get the ole truck finished up. Have stalled out on it for a while. Got a bunch of parts here or on the way.
New shocks and stabilizer. Skyjacker seems to have perfect fit and size. Won’t be here til tomorrow.
Rest of the trim pieces, emblems and hardware for inside and out. Now can get the new dash in and cab molding on.
New mufflers to replace the rotted out ones.
And last night I went after a leaking header gasket. I thought.
Found out it was leaking between one of the tubes and the flange. No big deal, new gasket and weld up what I thought was a bad weld maybe. Then I poked a screwdriver through the tubing! Gotta remove it and see how bad it is. I’m sure I can fix this spot, unless the rest of it is also rusting out.
So this is all I’ve completed and can’t even do it right. The repop emblems are not conducive to sticky tape and can’t reach inside fenders.
Got some work to doo.
Not conducive to sticky tape ya say? Well crap
fatguy54
