What can cause a backfire?
coachdtierney54
US
C30
Drove it to a friend's house and we put in a new radiator. We also found a huge vac leak in the carb spacer. I'm going to remove the spacer and replace the gaskets
Sent from my XT1254 using Tapatalk
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Good find on the carb spacer leak! This thing should be running like a champ soon enough!
coachdtierney54
US
C30
Is the carb spacer necessary? I run an edelbrock and it already has the mounting plate. That should be enough, right?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Eww why would he want it to run like an old Studebaker pick up? Lol sorry. I couldn't resist.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A spacer adds plenum volume and adds to the intakes air velocity as a high rise manifold does. If your running a dual plain intake the spacer if open will assist in top end air movement. If your just cruising around in low to mid rpm range it is not needed.
coachdtierney54
US
C30
Okay. I removed it. This is more of a work truck so I hopefully will not need it. I'll save it just to be safe.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
There you go no harm no foul. I run one but I need it to pull higher rpm. But in a work truck you'd want the low end power of the dual plain intake.
coachdtierney54
US
C30
Gotcha
coachdtierney54
US
C30
I'm going to scream. Not sure if I can road test it because I'm now leaking gas from the passenger side tank. I'm pretty sure the tank is rusting out.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Time frame is a Blazer/Burb tank swap. Just don't get discourage if these were easy everyone would have one the select few of us bring them back from the dead or from the brink of death.
coachdtierney54
US
C30
I thought I heard something come off the underside of the truck today, sounded like something was chipping away. I guess I know what it was.
Now for the question, if I do not use that side of the fuel system (and I haven't in the two years I've owned it), can I drive it?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I'd block the lines and drain it but if you haven't used it, it should be empty and ok to use.
Bowtie72
