What can cause a backfire?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Do you use the same OD size pipes butted up to each other with a band clamp?
They can be butt jointed or lap jointed with a band clamp. They are roughly 3 or 4 times the cost of a u clamp but well worth the money.​
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
I totally agree... I discovered them working on diesels. So far, I can only find them in Napa though. . Not Advance or Autozone. Never checked Peps
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Advance around here carries them they are like 12 something each, but there is an exhaust shop here in town that sells them for 7 a piece and that's 3".
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
You're lucky... no good exhaust shops around here either. Meinike.... but they're poop. :D
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Let me know what you need I will snail it to you 20 bucks for a 10 foot piece of 3" aluminized pipe with the ends flared.
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
I don't need it too soon... just got done putting a straight pipe in the dime... used those badass band clamps. Should be good for a Lil while. I'll hit you up when I'm doing the work dime. Need to remove the cat out of that.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
74 Shortbed
I just installed a Magnaflow kit on my Nova and it has the band clamps, they are badass I'll never use them junk U clamps again..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Did you use the 1.5" wide or 3" stainless with 2 bolts?
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
2 bolts here! Whhoooo...so easy to reuse too. I've never seen them rust.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
And if they get a bit stretched after reuse a bit of high temperature silicone does the trick.
74 Shortbed
Both, I used the 3" on a butt join and 1.5" on the mufflers since the mufflers slide over the pipe, the kit only came with the 1.5' for the mufflers and the Y pipe, I didn't want to weld the pipes to the header collectors so I just did a butt join on them with the 3" clamps, I can take it all apart in 10 minutes if needed
coachdtierney54
US
C30
Before I spend the money on new clamps, I found some u bolts that we're leftover from the install. I'm going to try those first. Any thoughts on where I should put them based on the picture I posted earlier in the thread?
Sent from my XT1254 using Tapatalk
Bowtie72
