- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
@Grit dog im going off these two recommendations. i dont use the truck much, so the joints arent warming up often. condensation and freezing are gonna be my enemy, and if the u joints have zerks, and like was said somewhere about sealed u joints are gonna not need touching but a zerk u joint is gonna go dry unless you pump it, yes? that means if grease can get out or dirt can get in, water gets in. I would LIKE to not touch these u joints for years, so i want to put in a grease that would compliment my use. SUCH AS A WATER RESISTANT GREASE THAT WOULD PREVENT OR HELP PREVENT THE FREEZING SITUATION THAT BROKE PART OF MY U JOINT ON MY AXLE SHAFT.
All my other grease is just regular, which isnt gonna shooo away water much. And wash out potential.
Beings the u joints are mostly going to have zerks, i figured i should pump them often esp if i know where they are
there are ways to give advice and opinions without condescension
i use to have a bad issue with it
I have a uniquely mud and snow, no high speeds or sustained speeds truck that i would like to purchase a grease that will give me hte most protection to ensure im not in these fuckers anytime soon and pumping grease periodically is cheap/easy way to do that and my reason for inquiring was I noticed a wheel bearing grease with PTFE for a trailer and i thought about how having water not get in and dry lubricating properties might not be a bad idea for my water-subjected truck
SO IF YOU HAVE A FRIENDLY ANSWER, I HAVE A FORCED SMILE AND WAVE AND EXPRESSION OF GRATITUDE WITH EXPANDED KNOWLEDGE.
if i type larger does that mean im louder??? :O
Not condescending, just think about what you're saying. The 2 "recommendations" you quoted above this, 1 I replied to above. The other was a response to your old unknown u joints, not new ones.
Pumping grease in them frequently is also a cheap/easy way to blow the seals out for good. Actually you don't even want to see grease come out and once you do, stop. Old u joints, the grease passages can get plugged where not all the cups are getting grease when you add it. Sure if you're in that situation, try to ram some grease through them and hope it gets to all 4 cups. Otherwise, give it a pump or 2 every 10k miles, maybe, if you're actually putting on some real driving? And 2wd miles don't count with your lockouts.
"Greasable options typically have recommended grease intervals for on-highway applications of 40,000-50,000 miles or corresponding to normal maintenance schedules." - From a machinery publication...
So my friendly answer is I use either A. Whatever is in the grease gun. Or B. my preference is Lucas Red n tacky. Idk why. Maybe because it works. Probably like most grease.
